It is currently Sat Dec 13, 2025 11:31 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Sep 27, 2009 5:36 pm
Did it get there under it's own power?
PostPosted: Sun Sep 27, 2009 6:08 pm
The project looks incredible so far. QUESTION...what kind of headliner is that? I need to do something with mine and would like to know what that is you did there if you wouldn't mind sharing.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon Sep 28, 2009 9:37 pm
yes..it got there under its own power.
the headliner was made from 1/8" panel board from home depot and 3m spray adhesive 90
question what are the stock rear end dear ratios
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Tue Sep 29, 2009 9:58 am
Maybe we should do a writeup on this, it gets asked a lot. Here goes-and this is for USA vehicles
LUVs had: 4.56, 4.10, 3.73. Your 72 is a 4.56. Later manuals had 4.10, some autos were 3.73 in the later days.
Some Pups had 3.73 and 3.42 (3.42 is the diesel MPG model).
Isuzu Impulse had 3.90 with a limited slip in manual trans.
All LUV 72-80 will interchange, and I have a 83 Pup rear in mine which is 3.73 that bolts in. I've heard of people getting later Pup rears where the driveshaft yoke doesn't match. Fortunately when I got mine there was also a LUV rear in the yard that I could compare to.
PostPosted: Wed Sep 30, 2009 2:09 pm
Moparich wrote:
Please explain further.
Do you have any more pictures of what you did???
I assume its 1/8" board with some sort of material stuck to it then just glued driectly to the underside of the roof. Is that right???
Cheers, Bob.
PostPosted: Tue Oct 13, 2009 12:06 am
mu son and i made a cardboard template of the opening. transfered that to the board with an added 1/4" to the perimeter.
then sprayed glued the thin carpet to it and forces it into position. probably have to break it to get it out
PostPosted: Fri Oct 30, 2009 8:20 pm
well change of plans
i came across a steller deal for one oif these
SR20DET S13 turbo
200hp stock
let ya guys know how it goes
PostPosted: Fri Oct 30, 2009 8:45 pm
Looks like it's going to be one helluva rig when it's all done. Thanks for the info on the headliner. One more question...is it just held in by the pressure of the extra 1/4 inch you added to the template? I need to do something with mine and I might have to borrow your idea for my own Luv.
The Kid's doing a great job! Can't wait to see the completed project.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Fri Oct 30, 2009 9:12 pm
Looks awesome! Great job!
PostPosted: Sun Nov 01, 2009 7:09 pm
yup the extra 1/4" is to hold it in
i had to make a revision to it after driving for a month it started to slide back and started to hang in the middle front. so i split som small 1/4" or 1/8" rubber hose and slid the hose over the lip in a couple places, adds a little pressure to it holding the carpet in place.. small problem fixed. cant even tell......now on to the sr20 installation and the quest for some different gears for the rear
PostPosted: Sun Nov 01, 2009 9:10 pm
One very important question. How much will you rent your son out for? He's pretty darn good! I'll give him free room and whore, I mean board too!!!!!!
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Wed Nov 04, 2009 7:45 am
has any one swaped in a early toyota pickup rear end into their luv?
PostPosted: Thu Nov 26, 2009 12:35 pm
trying to hide a intercooler on this lottle truck is pretty difficult
almost ready to fore it up
PostPosted: Fri Nov 27, 2009 1:10 am
That thing is huge i dont think you could hide it why would you wanna hide it? It has a turbo! :lol: good looking truck
2006 GMC Sierra 2500 HD
PostPosted: Thu Dec 03, 2009 10:33 am
just for anyone else who wants to try and put a 3" exhaust in a stock chassis luv :D
PostPosted: Sat Dec 19, 2009 2:15 pm
just an update plus my new dog 440
PostPosted: Wed Dec 30, 2009 1:57 am
So how big is that FMIC I was looking at at a 6x27.
What kind of WHP are you making and is controllable.
PostPosted: Wed Dec 30, 2009 1:56 pm
yup 6x27x2.5 FMIC
stock horse power for the s13 motor is 225 at 7 psi im running about 10 so maybe 255hp at the crank so about 200 at the wheel.
ive been comuting it the last 2 days 70 miles round trip took a little gettin use to the turbo kickin in about 4000. glad i havent put a posi in it yet as it just started rainin. but it does yank hard through out the gears pulls very well on top of the gears. i just havent found a place to test out the 75k redline. i am extremley happy with how it turned out driving it is easy and smooth surprisingly torquey and its nice to know you got that 10psi boost in your back pocket to smash on import cars.
the funniest thing so far was a del sol with stickers and probably some good bolt on mods stop with me at the the light i smiled at him rev my luv he took off hard i let him get about a car length smashed the pedal and waited for him at the next light. the look on his face was priceless. :lol:
PostPosted: Wed Dec 30, 2009 4:34 pm
if you get a chance would love to see a vid of the motor running and how it sounds... looks great. nice job
PostPosted: Fri Jan 01, 2010 9:24 am
i lost my fricken grill on the freeway. it was a bit broken up but looked good from far away. dammit.
hey ctmandu you got any grills?
try and do a driving vid tomorow
