It is currently Fri Jun 19, 2026 3:03 am
PostPosted: Sun Aug 03, 2003 7:33 am
I am getting ready to go back to the strip Friday. I have bought slicks(E/T Street 31x 14.50) and on the road it has made a HUGE difference. I mounted them on another set of wheels (plain steel) and it is back to leaving 2 black marks but I am going to put a mini spool in it anyway for the trip to the strip. It still spins but I hope at the strip and with some adjusting of air preasure I can get a good time out of it. I also like the gearing with the taller tires and might go to a 3.70 for the street.
I am waiting on final gear selection until I can get some good passes and see what RPM it is turning at the lights.
I am also planing on finishing the NOS system.I might need a little extra in 2nd or 3rd gearafter it hooks up.Wiring is all that is left, but I have let it go until I could put what it had to the ground.
I am off this week and it has started out with rain again. Last time I took off it rained all week to flood status. I will be working in the garage so as long as it quits by Friday I don't care. They are calling for rain for several days.
stripped and just a memory!
 Post subject: Rain???
PostPosted: Sun Aug 03, 2003 2:06 pm
Rain? What's that? Send some of it over here to North Las Vegas
Rick
PostPosted: Sun Aug 03, 2003 2:18 pm
Rat we got another Luv we use mostly just for the strip even though it is street legal. it dose only have a small block but just a 10 inch wide tire. we went 9.23 @ 145.6 on et streets in the 1/4 mile. it hooks hard but still spins out of the hole a bit . the tires will turn over about 3 times getting off the line. this is with a 175 hp shot of gas leaving with 1100 lbs of bottle pressure too. sounds like to me you just got to get a hold of the chassis adjustment on the rear and you will be on a ride. My truck gets driven daily and driven to the track . It goes 12.90's @ 105 mph and like I said is driven every day.
PostPosted: Mon Aug 04, 2003 7:02 pm
I agree on the adjustment part but it is going to be a trial and error process. I did get the chunk out today and the hub is broke that hooks the clutches to the axle , so I might as well had a regular chunk last time. The clutches are fine and I have another hub but I am just going to go ahead with the mini spool for now and know it will be sending the power to both wheels.
PostPosted: Mon Aug 04, 2003 7:07 pm
Rat... I'm going to have to take a day off and come watch you at the track.... Let me know when you're going again. You've sparked my interests over and over again.
PostPosted: Mon Aug 04, 2003 7:08 pm
the best short time I had the last time out was a 1.899. I had a 750 vac sec on it ... I changed to a 830 hp holley today and hit it once at the shop in the back lot .... I feel that my 60 ft will be a good bit better..only Friday night will tell ... Good luck with the rear end Rat .. Spanky
PostPosted: Mon Aug 04, 2003 7:55 pm
It is a good little trip from Memphis but I will be at the Brainerd Drag stip just outside Chattanooga at the Georgia line this Friday Aug 8th. It is looking like rain all week but clear for the weekend. Hope to see ya there!
I have been to several cruise ins and put several hundred more miles on this truck over the past few weeks and keep in mind it is a driver not a all out drag truck but still should turn a respectable time if I can hook up.
If you need the exit numbers let me know.
PostPosted: Mon Aug 04, 2003 8:04 pm
yeah.... 362 miles according to mapquest....
Damn.... Maybe some other time....
PostPosted: Mon Aug 04, 2003 8:50 pm
Rick
what the hell are you talking about? it was raining cats and dogs a few days ago!
PostPosted: Tue Aug 05, 2003 5:27 am
Thats about it on the miles.It was about 400 miles to St. Jude from my house . I made a couple of one night trips there and back several years ago when we took a car to a friend who was there. That is the only time I have been to Memphis and it was late at night both times but I remember it's a long drive.
PostPosted: Sat Aug 09, 2003 2:07 am
We went and here are the results.
made 9 passes 1/8 mile track
best time 7.342 slowest time 7.608
best MPH 93.01 slowest MPH 90.74
best 60 ft 1.652 slowest 60 ft. 1.775
Still spinning a little of the line but greatly improved over last time.
All motor.No nitrous.
PostPosted: Mon Aug 11, 2003 5:17 am
sweet!
maybe next time I will be in town and will get some video.
I still haven't found out how to compress the video I made for internet use....hopefully soon though.
03Cobra
PostPosted: Thu Aug 14, 2003 9:14 am
Hey KT1328, I am from Macon, I run at Reynolds in Pro, I have a puke yellow primer Luv in Pro ET, it runs low 7's and it is street legal, no nitrous I don't like killing my parts.
What color truck do you have, I will look for you.
PostPosted: Thu Aug 14, 2003 8:05 pm
Rick , my truck is white. I sent in some pics a couple of weeks ago but they havent made the pic board as of yet. I will be at the track in Reynolds this Friday night. I probally will not run my truck but will be with a friend whos car I work on a good bit . He lives in Macon as well and will be running his Black and White 55 chevy. Hope to see you there . I will have on a Reeves Performance uniform. The name will say Spanky.. Later
I was going to put a pic here but I am not smart enough to figure out how
PostPosted: Fri Aug 15, 2003 10:58 pm
Rick we will be driving my Luv truck the 80 or 90 miles to the cruise at Tanger outlet mall on Sat afternoon .. do you do the cruises or not ?? If you do and you go mabey we can meet ? Later Spanky
PostPosted: Mon Aug 18, 2003 7:45 am
Nope I don't do the cruise stuff, I am building a Datsun 240Z for the street right now for the street, I am trying to keep it mild. I tend to go over kill every time, and they turn out to not be very streetable.
It rained all weekend did not go to the track. :cry:
PostPosted: Mon Aug 18, 2003 8:57 am
you should have went it did not rain out on Friday night. we took my buddys 55 out and went 13.16 @ 106 with a 5 speed spinning through the first 3 gears .. we will be back out this comming Friday night too.. I am going to run my truck again.. may see you then
Spanky
PostPosted: Mon Aug 18, 2003 6:32 pm
that was me too
( Mental note got to log in before typing )
Spanky
PostPosted: Fri Aug 22, 2003 10:03 pm
OK just got in from the strip.. Happy as hell!!!! My little 40 over 350 went 12.74 @ 106.67 in the Qtr. after driving it to the track. which is approx 40 miles. I changed the pinion angle and got it to leave a bit harder without spinning as much. Still spin a little but think with a bit more practice I can get that problem sloved. ( I think I still had the air pressure to low ).
VERY happy with my 700 dollar 12.74 sec. engine YEAAAAA !!!!
Spanky
GOTTA GET A NEW LUV!!!!!!!!!
