It is currently Tue Jun 09, 2026 8:12 pm
 Post subject: Idler Arm grease seal
PostPosted: Sun Aug 23, 2009 9:49 pm
I was working on my 80 4x4 Luv. The Idler arm has a shaft that comes down through a housing. The housing has a bushing and a grease seal at the bottom. I replaced the bushing, but have not found a grease seal (the old one is shot). Anyone worked on this? Have you found a grease seal? Or maybe an alternative to that?
PostPosted: Tue Aug 25, 2009 10:42 pm
I forgot to put that the diagram is for the 81/82 Luv.
The Haynes manual doesnt have a good picture of the 79/80 4x4 Idler Arm.
PostPosted: Thu Aug 27, 2009 12:22 pm
I have a couple of the bushings left over, but I was able to reuse my seal. I wouldn't know where to find one.
PostPosted: Thu Aug 27, 2009 9:47 pm
Yea I tried one of the companies that makes the seals, you can search by dimenstion, but they didn't have anything that matched it.
I don't think the 2WD Luv's have the Idler Arm.
PostPosted: Thu Aug 27, 2009 10:08 pm
They do. I rebuilt the idler arm on my 80 2wd and 79 4X4. Same set up.
PostPosted: Sat Nov 03, 2012 3:33 pm
Did you have troube taking off top nut with grease fitting. Can't get mine to budge.
1980 shortbed Luv - 350 40 over, etc. - Like I told my momma, it ain't no fun growing up!
PostPosted: Tue Jan 29, 2013 8:18 pm
The top nut and grease fitting doesn't come off, at least I've never pulled them off. Just unscrew the shaft, clean all the old grease and grime out, replace the bushing, put the shaft back in pre-loaded with some grease (helps if the great fitting is out) then grease using the fitting. The idler arm design is really not so great IMHO as grease has to go through the threads of the shaft, and I always said the next one I re-did I would drill and tap a hole in the side of the bracket for a second grease fitting.
The 2WDs and the 79-80 4WDs do have the same shaft and bracket. The arm itself is different though if I recall.
