It is currently Tue Jun 16, 2026 4:24 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Sun Jun 14, 2009 8:52 am
At the rate you're going, you should be through by Tuesday...
PostPosted: Sun Jun 14, 2009 5:24 pm
Cut both off and swap sides. And it looks like a 70 pick up.
Killing all Big Blocks .
PostPosted: Sun Jun 14, 2009 10:10 pm
LSX LUV Owner
i wish!
PostPosted: Mon Jun 15, 2009 9:03 pm
Lookin' good. I did mine sorta the same way with square tubing but didn't have the rounded top and my is just squared off at the bottom.
PostPosted: Thu Jun 18, 2009 12:40 pm
LSX LUV Owner
got the brake setup all tacked together.. hopefully it all works out ok... and got ac box mounted
PostPosted: Thu Jun 18, 2009 2:41 pm
cool setup for the brakes
PostPosted: Thu Jun 18, 2009 3:47 pm
With the master and brake lines in the cab, it sure will make the engine compartment clean. Nice work.
PostPosted: Thu Jun 18, 2009 6:40 pm
:signiagree
PostPosted: Thu Jun 18, 2009 8:39 pm
LSX LUV Owner
yeah ive seen setups like this for a while, just didn't want to shell out the money for the bracketry..
werd! all i will have coming out of firewall is steering column, heater hoses, ac lines, hood latch cable, throttle cable.. i plan on hiding all brake lines and wiring from firewall.
WildLuvRacing1974 wrote:
:signiagree
thanks!!
couple more pics.. moved ac box up some, and did some more welding..
and got my windows tinted on my daily finally.. 5% all around and 50% over entire windshield..
PostPosted: Thu Jun 18, 2009 11:28 pm
Love the idea and the work, but are you going to be able to access the master okay for filling and or bleeding?
PostPosted: Fri Jun 19, 2009 6:30 am
LSX LUV Owner
i positioned it to where its at the center of the dash, and i will have something that looks like a defrost vent that is removable so i can fill the mc..
PostPosted: Sun Jun 21, 2009 12:04 am
Not trying to hi-jack , but do you think a LS based motor/4L60E would go in the stock engine bay without cutting the firewall ? I mean custom mounts and headers , but stock suspension factory look with LS under the hood .
PostPosted: Sun Jun 21, 2009 9:31 am
LSX LUV Owner
sending pm now..
PostPosted: Sun Jun 21, 2009 11:35 pm
Question.
So is the point of your truck to look good lowered to show, or go fast? Or do both? I can't seem to figure that out...
Love the build btw.
PostPosted: Mon Jun 22, 2009 1:01 pm
lookin good man i need to get back started on mine iv been kinda lazy on it for about the last month
PostPosted: Mon Jun 22, 2009 2:42 pm
LSX LUV Owner
Dudeus wrote:
Question.
Love the build btw.
Look good, run decent, and be fun as hell to drive the shit out of it. I do t think Id say it'll be fast fast.. Eventually it will be..
Get on it slacker!!
PostPosted: Wed Jun 24, 2009 11:05 am
lol most of the reason is because of work we had some bad storms here an di work for city public works and we have to clean up after that shit happens so iv been working non stop
PostPosted: Wed Jun 24, 2009 9:07 pm
LSX LUV Owner
selling/trading bogarts to my dad.. getting his cheapo summit wheels + cash in return.. gonna rock them till truck is running then im buying these..
PostPosted: Thu Jun 25, 2009 8:54 pm
LSX LUV Owner
cheapo wheels on.. brushed two of them :haha: . gonna get some rougher scotch brite pads and hit em up some more. i like the look, just think the rougher grit will make it more defined and look better. plus i need to go over them better.. only spent about 10 minutes per wheel..
and bogart on dads car...
if i decide i dont like.. black powder coat, here i come!
PostPosted: Thu Jun 25, 2009 9:15 pm
those cheapys are pretty cool
75-luv mikado-V8 350 soon
