It is currently Tue Jun 30, 2026 8:22 pm
 Post subject: Chevy 305 In My 79'
PostPosted: Tue Jun 02, 2009 2:07 am
I was wondering if anyone knows the capabilities of the automatic turbo 200 transmission
i want to drop a 305 small block in it and wanted to if i drive it normal would it hold up?
:egeek
Image Image
 Post subject: Re: Chevy 305 In My 79'
PostPosted: Tue Jun 02, 2009 7:52 am
:smt078
you will not be happy
and sorry i dont care who you are, ya put a v8 in a luv your gonna want to break the tires loose occasionally, and that tranny wont hold up
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Tue Jun 02, 2009 8:21 am
The TH 200 is what the stock LUV auto trannys are.
PostPosted: Tue Jun 02, 2009 9:18 pm
Obviously im not planning on keeping the tanny but i dont have money right now to change it over to a TH350
i just want it at bare minimum drivable so i can get it out of garage.
Just granny drivin is all i need to get by
until i have the money to change the transmission
Image Image
PostPosted: Tue Jun 02, 2009 9:29 pm
I don't think it will bolt up...
PostPosted: Wed Jun 03, 2009 7:23 am
The TH200 came in alot of GM cars,even some of the big ones like mid to late 70's Caprice 4drs.
The ones that came in the LUV trucks had a special bellhousing and torque converter made just for the Isuzu engines.
PostPosted: Wed Jun 03, 2009 11:45 am
how bad do you need a th350?
I got one in storage in tacoma, not too much of a drive south for ya. its been worked over pretty decently, but id cut ya a good deal!
A.j.
PostPosted: Wed Jun 03, 2009 11:46 pm
Ah, ok well i wasnt holding my breathe or anything just figured "why not" just ask
:lol:
TH350 you say? What have you had done to it?
also what did you have in mind price wise?
:egeek
Image Image
PostPosted: Thu Jun 04, 2009 7:14 am
has been givin a full gut check, with nessacary upgrades - trans break, input/out, deep cast pan, etc etc... but it needs a torque converter.
looking to get 500$ for it, should be solid into the 750HP range or roughly low 9s in a 3200lb body.
A.j.
PostPosted: Fri Jun 05, 2009 12:55 am
Turbo 200 came behind the 305 in some heavier cars . It has the same overall length as the TH350 and the trans mount is within a 1/4". The set up can use the same bolt in adapters as the 350, TH350. It will not hold much stop light grand prix action. However it can be used as a driver. The TH200 was updated to the TH200R4 overdrive in later years. Check out http://www.photobucket.com/V8luv also http://www.powerbyace.com in the technical section has instructions for bolting in the V8 and trans.
