It is currently Wed May 06, 2026 8:51 pm
PostPosted: Wed Apr 01, 2009 5:16 pm
ok great news budget change :ebiggrin my girl said go nuts so it looks like little bear is going sas chev 305 or 350 and rear axle change out as needed first question what can i fit under the front is toyo the only real option and can my 5spd man hold up to a mild 305 if you have gone this route talk to me this going to be my hunting slash bash rig i really dont care if i break then build up i have a f150 for daily duty and haul out :lol: so lets talk redneck build oh and we are going psuedo sleeper suede black paint already done ane mild exhaust sand mud rock she shall see all :twisted: :twisted:
A man is judge not by the size of his tires, but the of kind men he leaves behind.
93 f150 5.0 4x4 s-cab "work horse"
65 mustang 200cu "project pony"
[79 chev luv 4x4 "budget wheeler/ gas myser"
PostPosted: Wed Apr 01, 2009 5:27 pm
Use the search icon on this site. There are all kinds of threads about V8 swaps.
Most popular is a small block Chevy with a 350 or 400 auto trans. They will bolt together. The stock 4 speed won't bolt up to the back of a sbc.
PostPosted: Wed Apr 01, 2009 6:13 pm
thanks rondog what about the axles i know to get more lift then what i got from the tb already done i need a straight axle swap what rigs make fair donors if i can go chev i would prefer it and probably be cheaper you know toyos are pretty popular right now.i was also thingking i would have to relocate my radiator to bed roll bar is this true. and transfer case is that pull out too i know lots of question thanks this is my first small four byand the rules seem different from theri larger cousins :?:
PostPosted: Wed Apr 01, 2009 10:54 pm
Oh is it a 4X4 now?? If so the t case is part of the trans. so you you would have to find a separate eng., trans., and t case for a swap. IDK about the axles. Someone else on here could help I'm sure. Plus like I said, use the search feature and you'll be reading for hours. This site is FULL of useful info. Good luck.
PostPosted: Wed Apr 01, 2009 11:23 pm
sorry i thought i said that. my bad by the way scored a toyo rear axle for it for ten bucks not bad but it is a real pain to find the straight axle fronts by the way nice ford (photo bucket)looks like mine only red instead of white is that the e4od you got under there or the aod i love my e4od especially on a 150 but i have to put in the heavier duty bearings and some more of the later model 3/4 ton gear into mine. back to the luv who would know more about axle interchangeability i checked the search button and got lots of vague info and even something about a wagoneer axle , but anyway i will look again thanks again ron dog by the way hows your mileage in the love with the camper on it :lol:
PostPosted: Wed Apr 01, 2009 11:56 pm
On axles, it really depends on how hard you are going to use it. Now, a Dana 30 SHOULD work for you, but if I were going to do it with an unlimited budget, I'd go rockewells under the front and rear. Or another hella beefy option would be a Dana 60 in the front, and a 14 bolt in the rear.
And for engines/trannys/transfer cases... I'd go 383 stroker, turbo400, and I believe its the 221 transfer case, but I'm not sure about the transfer case.
Buuuut, thats just me. Engines and axles are based ALOT off of opinions.
PostPosted: Thu Apr 02, 2009 5:55 pm
rock wells would be nice but arent the too large and at that point might as well just stack my body on amodified blazer rolling rame, do you guys think a toyo set up front and rear would hold up to a 305 350 power plant running chev trans and tcase oh thank heaven for craigs list :lol:
PostPosted: Thu Apr 02, 2009 7:55 pm
Yea, it would hold up, you just have to have the right gears and beef up your axles a bit.
PostPosted: Fri Apr 03, 2009 11:18 am
The Toyo axles will work and if you want to beef them up then get the V-6 diff's as they are alot stronger then the 4 banger diff's.
PostPosted: Fri Apr 03, 2009 10:12 pm
sweet do you mean the whole third member or just ring and pinion gears by the way any body from oregon going to the big auto swap meet in portland 3,4,5 i was wondering if it would be worth my while i know ill find stang parts for her ride but not sure how i will do for parts for the luv. also i know they make mount conversion kits for the 350 is this also availible for the 305? thanks again guys viva luv :)
PostPosted: Sat Apr 04, 2009 11:25 pm
The adapter kits are the same for the SB 283, 302, 327, 350, 400 CI engines. The toyota axles do well with the Chevy engines. If you want to use the later toyota transfer case there is an adapter made to bolt it to the rear of a TH 350 trans. I believe the Dana 30 or was it 20 transfer case is what was used in the pre factory 4 x 4 conversions. They made a cradle to mount it in. They used the Dana 44 axes in the front, stock in rear. Some has the Dana 44's also in the rear. The Dana 60's stuff is just too heavy unless your going mud bogging or some other kind of race gig. Use a 4/5 speed, TH350 or 700R4. The TH400 requires too much work to properly get it installed.
There is a picture of 4 wheel drive SB headers at www.photobucket.com/v8luv
