It is currently Mon Jun 08, 2026 6:11 am
PostPosted: Wed Mar 11, 2009 1:49 am
Ok quick question about my 76' Luv
when i turn on my headlights
only 1 bulb will work on low beams
but when i turn on the high beams all 4 work
im at a loss for words because it was working
:microwave:
Image Image
PostPosted: Wed Mar 11, 2009 11:16 am
Fuse
They are all fused separately. Had approximately the same thing happen to me.
PostPosted: Wed Mar 11, 2009 1:07 pm
Sounds like the low beam in the headlight burned out, try switching the outer lights with each other, if it does the same thing on the opposite side then is the bulb.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Mar 11, 2009 8:26 pm
Australian LUV Guru
All four globes should be single element type, if all four light up on high beam this rules out a blown globe.
My guess is the problem is in the low beam wireing circuit, either at the headlight swich or low/high switch. Ive seen many high/low switches go bad because people fit higher wattage globes and dont use a relay.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed Mar 11, 2009 9:27 pm
If the low beam circuit is blown. Why does the low beam still work on only the passenger side
and not the drivers side? And then all 4 lights work on high beam only ? :? :econfused
Image Image
PostPosted: Wed Mar 11, 2009 11:05 pm
High beam is separate from low beam and there is separate fuses for left and right head lights.
PostPosted: Thu Mar 12, 2009 1:19 am
I believe you will find that the outside lights are dual filament high and low beam. The inner lights are single filament high beam only. So you probably still have a burned out bulb.
PostPosted: Thu Mar 12, 2009 3:30 am
Australian LUV Guru
Egg you may be correct. I forget theres some differences between the Luvs here in Australia and other parts of the world. Here in Australia all the Luvs i have owned have been fitted with single element globes.
It makes more sense to have a double filament in the outer globes, wonder why it wasnt so here in OZ.
PostPosted: Thu Mar 12, 2009 4:42 am
Oh, sorry i havent been with it much lately ive been so busy but i understand
ill purchase a new bulb and let you guys know if that was the cause
Image Image
PostPosted: Thu Mar 12, 2009 10:43 am
For my $0.02 get a multimeter and test the filaments before you buy a new bulb. They should either be continuous or have a resistance associated with them. If they are open then they are blown, get a new one. I would hate for you to buy a new one and it not be bad. Also, I heard you should replace headlights in pairs, if you are going to replace them, because they dim gradually so you don't want a new one that's bright and an old one that's dim.
PostPosted: Sat Mar 28, 2009 12:51 am
Well i swapped the bulbs on the outsides (low beams) to see if it was the bulb
the one that wouldn't work, worked fine on low beams on the other side
so its definatly not the bulb
what the hell else could it be
i put new fuses in it, Used a different High/Low beam switch, I also cleaned and looked at all the grounds.
STILL NOTHING
any ideas?
Image Image
PostPosted: Sat Mar 28, 2009 1:02 am
The high low beam switch? Just a guess.
