It is currently Tue Jun 16, 2026 1:08 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page 1, 2, 3, 4, 5 ... 57  Next
 Post subject: LUV II
PostPosted: Sun Feb 15, 2009 3:00 pm
LSX LUV Owner
got the luv rolled into the garage. figure id start a little project thread n post my progress. going to be slow going for a lil while. for now, im just gonna pull the motor/tranny, clean up engine bay, fix rust on the floor, and few other little things. by then i should have my blazer paid off and then ill start buying parts for v8. i told myself is wouldnt do any work to the truck till my blazer is paid off, so im gonna stick to it!
so far only have radiator out, wiring removed/cut, other misc. lines n stuff removed and out of the way. im about to go back out n remove driveshaft, exhaust, and everything else so the motor n tranny is ready to be pulled.
 Post subject: Re: LUV II
PostPosted: Sun Feb 15, 2009 8:38 pm
LSX LUV Owner
lil progress
PostPosted: Sun Feb 15, 2009 10:02 pm
8O I would say that is alot of progress!! Looks like you coming along nicely with the tear down.
PostPosted: Mon Feb 16, 2009 10:03 pm
LSX LUV Owner
took some more stuff off the firewall, and took out pretty much all wiring from dash. i left some wires coming off the brake light switch, out of the column, off wiper motor. not sure what im gonna need/want to use to tie into the new harness. also took apart an extra door and took all the parts out of it in case i need anything.
wet stuff is coolant from heater core
mmm
back of truck and front of his car are the same, look how short his is :haha:
PostPosted: Tue Feb 17, 2009 9:53 pm
LSX LUV Owner
MANNNNNNN. this forum is so lively. damn
PostPosted: Tue Feb 17, 2009 10:06 pm
That gives you time to work on the truck... :lol:
Seriously though, lot's of progress... 8)
PostPosted: Wed Feb 18, 2009 1:18 pm
LSX LUV Owner
thanks man.
made a lil patch panel while i was waiting on my pizza. might get it welded in tonite. its my nieces bday so who knows..
PostPosted: Wed Feb 18, 2009 10:33 pm
LSX LUV Owner
took windshield out and started repairing rust.. my first time doing anything like this.. so hopefully itll turn out nice. ill grind down the welds tomorrow then add in the last piece. (the piece sitting there isnt going to be used, i just sat it in there.) i will make 2 of the same pieces and hopefully have it look factory :haha:
PostPosted: Wed Feb 18, 2009 10:39 pm
Looks like you are coming along nicely. Good work.
Some times I amaze even myself!!!!
PostPosted: Thu Feb 19, 2009 12:45 pm
LSX LUV Owner
Dad started making me 5 lug hubs so my wheels dont get pushed out any
PostPosted: Thu Feb 19, 2009 5:11 pm
Awesome!! That would be nice to be that talented.
PostPosted: Thu Feb 19, 2009 8:27 pm
LSX LUV Owner
he made them to where it should actually push the wheel in almost 1/4"... they will be finished tomorrow. he needs my rotors to finish them.
PostPosted: Fri Feb 20, 2009 9:21 pm
LSX LUV Owner
heres what i got done today... some pics are off phone cause i didnt have camera with me...
had this rocker replacement screwed in over the factory rusted to shit rocker. didnt know it was so much work...
all this minus the paper towels was in the rocker
other rust spot
rust up here.. cut it out and replaced
does anyone see a reason why i cant close up all these?
where i left off for the night
PostPosted: Fri Feb 20, 2009 9:28 pm
PostPosted: Fri Feb 20, 2009 10:42 pm
Sand blast the hell out of it when your done with all the rust repairs.
PostPosted: Fri Feb 20, 2009 10:53 pm
Any chance two sets of those hubs were made? :)
PostPosted: Sat Feb 21, 2009 11:16 am
LSX LUV Owner
sending you a PM...
PostPosted: Sat Feb 21, 2009 12:03 pm
LSX LUV Owner
well i found another luv truck. going to look at it tomorrow. only wants 200 for it. he says it has the typical rust, but the bedsides are in good shape and the bedfloor has holes in it from being cut. has a dana rear end under it as well. so as long as the bedsides are actually in good shape, im going to buy it for the bed and rear end. maybe cut the passenger rocker off if its in good shape, and whatever else i need/can sell for moneys. then put my old parts on it and send it off to the junk yard.
PostPosted: Sun Feb 22, 2009 8:56 am
After looking over the good looking work your dad is doing may i suggest that you use the pre 87 Trooper rotors as they are vented and half the weight of the stock Luv rotors.I your dad can make these hubs at a good market price and using the Trooper rotors i would venture to say you have a way to off set some of your build costs and i even might be interested to.
PostPosted: Sun Feb 22, 2009 3:40 pm
you got to people that if they are the right price id put the money into them. my uncle has a metal lathe im going to see if he wants to try and make me some.
Users browsing this forum: Baidu [Spider] and 22 guests
