It is currently Sun Jun 28, 2026 4:31 am
 Post subject: please can some one help
PostPosted: Sun Feb 15, 2009 8:54 pm
So I broke off i think its an egr valve can any one post a pic swowing me where it is I just found it on the ground when I put the engine in yesterday and one more thing could some one also post a pic of the top and side of a 1.8 liter so I can figure out where the hell all of the vacuum lines and emmision lines go. Thaks a million
currently working on my 1977 luv truk
PostPosted: Sun Feb 15, 2009 11:02 pm
the egr valve is located on the under side of your intake manifold. there is a pipe running from the exhaust manifold along the fire wall and into the bottom of your intake manifold. it connects in underneath. you may have just broken off a vacuum control or valve. there are several in different places around the engine compartment. your vacuum line diagram is on the hood. also, do a search for vacuum lines and look at the pics in this forum and you'll find what you need. good luck!
PostPosted: Mon Feb 16, 2009 1:27 pm
So its not an egr its a ported vacuum switch
PostPosted: Mon Feb 16, 2009 6:37 pm
Is it for the egr or vac. advance? There is a vac. switch that screws into the front of the intake manifold.
PostPosted: Tue Feb 17, 2009 7:41 pm
yea its that one on the front of the intake. i went to the parts store and they want 52 buks for it so im gunna try to jb weld it and hope it works cause i dont have 52 buks
PostPosted: Tue Feb 17, 2009 7:49 pm
Basically all it does is keep the EGR from opening when the engine is cold, I never ran mine I just hooked up the vac straight to the EGR.
Users browsing this forum: Majestic-12 [Bot] and 91 guests
