It is currently Wed Jun 03, 2026 8:16 pm
PostPosted: Sun Jan 25, 2009 1:13 am
I was looking threw some of the pics and you guys who have bagged your luv what are you doing to get it to lay frame? Like what are you cutting out to allow it to lay out in the front? I know how to get it to lay out in the rear just stumped on the front. Trying to get all my info straight before I go off and start ordering stuff. Thanks Le :twisted:
PostPosted: Sun Jan 25, 2009 2:00 am
To get the front to lay out your going to need to Z the frame, pie cut the upper control arm and eliminate the factory strut rods by triangulating the lower control arms. Also if you want to install a 2500 lb bag up front, the frame under the shock tower will have to be notched so it will clear the spindle.
Honestly it would be cheaper and faster to just do a front suspension clip swap out of a toyota or a mazda depending on what lug pattern you want to run. The benefits would be more room to install a larger bag for a smoother ride, better camber angles and lift.
1975 V8 Luv
1980 Bagged Luv
