It is currently Fri Mar 20, 2026 10:27 pm
 Post subject: Leaf springs
PostPosted: Fri Sep 05, 2008 10:08 am
:? Can the leafsprings be fliped over to add lift to the frame 79 4x4????
Thanks
[b]Sandy Orr - Keeping the world Green and Growing
 Post subject: Re: Leaf springs
PostPosted: Fri Sep 05, 2008 12:51 pm
Are you talking flip the springs to be on top of the axle?
If so yes, and it's pretty easy to do, plus you can do a shackle reversal at the same time... Did mine in an afternoon by myself on my truck bed trailer :egeek
PostPosted: Sat Sep 13, 2008 9:46 am
You might want to rethink this on my 80 4X4 had the spirngs on top of the axles when I bought it. I didn't think tomuch about it until I had to slam on the brakes and the axle slid back and locked up the E-brake because the alinment pins could not be moved.
The only way to truely know your vehicle is to take it apart and rebuild it from the ground up!!!!!
80 LUV 4X4 Mods(Holley fuel injected 4.3 700R4/ 208 Transfer Case)
79 LUV 4X4 Mods (350 Project)
PostPosted: Thu Oct 02, 2008 2:04 pm
post resurrector
I dont see any problem, we did it on my buddies '78 and he was able (with a shakle flip) to fit 33s, not bad for preety much stock.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
PostPosted: Sun Nov 23, 2008 4:35 pm
what shackles could you use to raise the rear and still leave the springs under the axle.
PostPosted: Sun Nov 23, 2008 6:41 pm
wouldnt this only lift the rear? since the front is ifs. i think it would look goofy
No luv right now =(
PostPosted: Sun Nov 23, 2008 7:00 pm
YES REAR LIFT ONLY WITH THIS. WOULD THESE WORK?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... :IT&ih=011
