It is currently Fri Apr 10, 2026 5:24 pm
PostPosted: Fri Dec 08, 2006 11:30 pm
Hey all, i adjusted my torsion bars up the other day. It raised my front end a little, provided me with the clearance i needed for the bigger tires i put on, and it looks pretty darn cool like that. What I don't understand is the fact that i have about no travel with suspension at all. That isn't good. I need to know if there is a way to fix that so i have some front end travel, and smoother ride.
Also, I was wondering if it would behoove me to install a different rear axle in there. Have many people done it, and what are advantages and disadvantages? Also, What axles are best to use- dana, or isuzu or something else? Thanks, Nick.
Thanks, Nick.
PostPosted: Wed Dec 13, 2006 11:23 pm
Did you crank up the torsion bars to the point that they've topped out? There's bump stops at the upper a arms. If you crank to much on the bars, you'll end up with a preload on the bump stops. That's how you can tell that you've cranked too much.
This makes for a SOLID riding truck for sure.
An S-10 axle is the most popular rear axle swap for stock and mild V-8 powered trucks. 4X4 trucks are far more involved when it comes to front and rear swaps.
PostPosted: Fri Oct 10, 2008 7:15 am
post resurrector
If you cranked the TB's you cant get a good ride because there is more stress, aint going to ride good. 8)
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
PostPosted: Fri Oct 10, 2008 8:12 am
And being that this was almost 2 years ago when he asked, I'm sure he got it figured out by now. :roll:
PostPosted: Fri Oct 10, 2008 9:18 am
post resurrector
Yeah I hope so, didnt even look at the date :lol:
BOOMER SOONER!!!
PostPosted: Fri Oct 10, 2008 8:48 pm
Um, like all your other replies also. We appreciate you trying to help others but please be aware of when the posts were made and left to rest. Thanks! :eugeek
