It is currently Mon Jun 08, 2026 11:31 pm
 Post subject: leaf spring conversion
PostPosted: Wed Oct 01, 2008 10:43 am
post resurrector
I need advice on switching my 4wd to leaf springs instead of those retarded torsion bars.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
PostPosted: Wed Oct 01, 2008 8:43 pm
Toyota axle or frame conversion
PostPosted: Thu Oct 02, 2008 12:59 pm
post resurrector
I was thinking about dana 60s mainly because I am puting a 364ci cadillac under the hood.
BOOMER SOONER!!!
PostPosted: Thu Oct 16, 2008 8:59 am
i think 60s are weaker than 44s if i remember correctly (probally not!)
PostPosted: Thu Oct 16, 2008 7:49 pm
That is incorrect. The 60 is stronger than the 44. Rockwells are bigger...
PostPosted: Thu Oct 16, 2008 8:09 pm
i thought there was a disadvantage to the 60 over the 44 but i'm by far not a expert on danas.
PostPosted: Fri Oct 17, 2008 6:48 am
post resurrector
I dont think the 44 would really hold up to 40in tires, I will probably just use the dana 60 in the front, and a 14 bolt in the rear.
BOOMER SOONER!!!
PostPosted: Wed Oct 22, 2008 4:18 pm
the only "disadvantage" you might call it to a 60, is i dont think a 15" rim will fit....just go 17" bling! and no a 44 wont hold up to 40" tires, not even with chromos..... I'm gonna try and feather it with my 39"s this winter... :P
What advice are you looking for really? in leaf springs there are a lot, and I would worry too much about the caddy pushing that much HP :lol: Are you looking for advice on what style of leaf to use or what?
do you have a set of axles lined up?
PostPosted: Fri Oct 24, 2008 10:59 am
post resurrector
No im just trying to get some ideas, but I have already started on it I bought some 6'' lift springs for a half ton chevy and I got the rear mounted, still working on the front, thanks for the advice.
BOOMER SOONER!!!
