It is currently Mon Feb 02, 2026 1:21 am
 Post subject: Dell'orto carburetor
PostPosted: Sat Aug 09, 2008 9:38 pm
Any one try one of these carburetor on their Luv's? We use them a lot on VW engines. I don't know how they would compare to the Weber. We use both. I have used the weber progressive carburetor on VW's up to 2.0l Engines so the should work. Kradons I have the weber on my 2.0l Porsche 914 engine. But dual Dell's would give me more performance.
Dual Dells on a hot 2275 VW
http://www.chircoestore.com/catalog/index.php?cPath=133_460_558
 Post subject: Re: Dell'orto carburetor
PostPosted: Sat Aug 09, 2008 9:47 pm
i had duals on mine works great for performance but gas mileage was down... will put them back on when my truck is just a summer time toy, not a daily driver
PostPosted: Sat Aug 09, 2008 9:52 pm
They are "purty"
PostPosted: Sat Aug 09, 2008 9:58 pm
look and sound great sucking massive air threw the velocity stacks... also had a single on first
and the duals, but you have to mount washer bottle sideways
PostPosted: Sun Aug 10, 2008 12:23 am
WOW the 2 Side Draft Dells look great. The single 'dell looks good. How did the signal Dell work. I was think of a single Down Draft in place of the Factor carb.
PostPosted: Sun Aug 10, 2008 12:55 am
worked great , better then the weber 32/36 with header cam ... the only video i have is while i was jetting them so it wasn’t running right at the time of this video and the echo sound at the end of the video is my hood rattling
PostPosted: Sun Aug 10, 2008 9:47 am
Unless the Webers were IDA's, I would throw them away in VW's and get a set of Dell's.
PostPosted: Sun Aug 10, 2008 10:26 am
You guys consider yourselves lucky, we have a little problem with brake resiorvors being in the way for pretty bits of kit like that.
But i do have a single sidedraft lynx manifold and a 42DCOE here. :ewink
Bob.
PostPosted: Sun Aug 10, 2008 12:04 pm
i have seen some use brake resiorvors relocators to do it ... how was the 42 dcoe?
i like this set , nice and clean
PostPosted: Sun Aug 10, 2008 6:11 pm
Bob.
All your stuff is on the wrong side. :lol: I could see where the master cylinder could be in the way.
PostPosted: Tue Aug 12, 2008 12:24 pm
I can use the master cyl out of a WFR van, its got a remote mounted tank and the bolt up pattern is the same as the one on the Luv and it needs replacing anyway.
The tank is setup for 3 supplys, one for the clutch master as well. Might need to chase up an early pedal setup.
Im not sure what to do with the 42DCOE. I have the manifold and i have a rebuild and soft mount kit. It does need to be re-choked etc as from what i can tell it was on a really small motor. I also have a 40DCOE here but it would be too small. I have a 2.6L thats going in my pup, if the 2.3L carb wont do it ive got a 34ADM here that came off a 200cid 6 cyl.
I want to try EFI on the Luv, its only got a G161Z engine in it and i have a TBI setup here off a 1.6L that i want to adapt to the motor. For now its going to stay stock with gas prices being what they are. Works out over $6.50 a gallon, for that money im happy to just poke along.
A man has to save up in advance just to fill a fuel can to go play dirt bikes.
Back when i was a younger man you could fill it up with loose change.
Bob
PostPosted: Sat Aug 16, 2008 9:51 pm
Hey ctmandu where can I get a carb like that? I wanna run a single dell maybe dual with my 4bbl offenhauser intake. Im thinkin about makin an adapter if I can get ahold of one of those carbs.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Aug 16, 2008 10:41 pm
you could use one like this http://cgi.ebay.com/ebaymotors/ADAPTOR- ... enameZWDVW
ore one like this
http://cgi.ebay.com.au/V8-TWIN-WEBER-MA ... m153.l1262
and for here in the states http://www.jameng.com/products/index.phtml?section=12
like this for you
or for guys with 32/36 the could use this to add side draft
as for carbs i got all mine from this guy, great person to deal with http://stores.ebay.com/ALFA1750S-CARBUR ... ARTS-STORE
PostPosted: Sat Aug 16, 2008 11:27 pm
Awesome! :D Thanks man
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Aug 17, 2008 12:12 am
your welcome... the guy in Italy is great and when i got my 40 dell's i paid $230 total for them... anything i found here was $600 to $1000 at the time, and well used...he said they are getting harder to find over there now but still he can get them and all of his are cleaned and jetted for what you want (good base line anyway) he cant make it perfect out of the box ... prices have gone up sence then
last set of solex’s i got from him like in the picture of my luv and shipping was or is $36 http://cgi.ebay.com/ebaymotors/SOLEX-C4 ... QQtcZphoto
PostPosted: Sat Aug 30, 2008 7:37 am
Sorry but you cant, ive got one of these, i bought it used off eBay for a good price. Once it turned up i was stoked. About 3 months later i was looking at it and i realised that if i used it on my Luv/pup it wouldnt be a side draft it would be a front draft. Its a side draft adapter for a FWD east-west engined car. To use it on a RWD you would have to put an adapter under it.
Im lucky, it just so happens that ive got an N12 1.6L manual Nissan Pulsar here and its loaded with smog shite, I can see the 40DCOE going on it once its past its Roadworthy check and registered and back on the road.
Bob.
PostPosted: Sat Aug 30, 2008 9:14 am
they also make this one
PostPosted: Sat Aug 30, 2008 7:05 pm
yeah that one would work better.
