It is currently Mon Jun 08, 2026 8:15 pm
 Post subject: Disk brake swap
PostPosted: Tue Aug 05, 2008 5:58 am
I recently did a disk brake swap on my '75 and I have a question. The drum brakes have two nuts that hold the brake hose to the frame. The disks have a nut on the brake side and a groove in the portion that goes through the frame bracket. I picked up a couple of pins, sort of hourglass shaped, that I slipped over the bracket and around the hose fitting groove. It seems to work but it looks a little weak. Is there a better standard part or pin that does the trick? I'd love a picture if you have one since this is hard to describe.
Khy in Austin, TX
Pert near on the road again
 Post subject: Re: Disk brake swap
PostPosted: Tue Aug 05, 2008 10:43 pm
Australian LUV Guru
Like This?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun Aug 10, 2008 3:39 pm
Yup, that's it. Do you have any idea what those are called. I'm at the parts store tomorrow and I'd like to get a couple.
PostPosted: Sun Aug 10, 2008 6:33 pm
http://www.brakequip.com/fitpdf/misc.pdf
Brake Hose Retaining Clip
PostPosted: Mon Aug 11, 2008 12:03 pm
Nice. Thanks
