It is currently Thu May 07, 2026 3:22 pm
Post new topic Reply to topic  [ 246 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 13  Next
 Post subject: Re: truck pic's
PostPosted: Thu Jul 31, 2008 4:00 am
looks good mytmouz, when you going to install and use it?
PostPosted: Thu Jul 31, 2008 11:58 am
It's in now. I plan on going for some shake down passes next weekend if the weathr cooperates, but I don't know if I'm gonna spray it until I make a couple of shakedowns. I made a lot of changes to calm it down for the launch and i need to check them out first...
PostPosted: Fri Aug 08, 2008 1:25 pm
IT MOVED! :lol: First time out of the garage since May of 07... 8O Needs a bath...
PostPosted: Fri Aug 08, 2008 3:27 pm
Swap Specialist Mod
burnout video or ban!!!
haha jus kiddn
looks good man!!
PostPosted: Fri Aug 08, 2008 3:42 pm
Let us know how things go at the track. Looks good.
PostPosted: Fri Aug 08, 2008 4:35 pm
you havent drivfen it since 07??? :?
i always thought it was like a street strip truk 4 you! :oops:
PostPosted: Fri Aug 08, 2008 4:39 pm
It was broken...
Washed loaded, and ready to go, Sorry Farmer Joe, I don't have a videao camera, or a camera phone...
PostPosted: Fri Aug 08, 2008 5:39 pm
Is that a Nissan pulling the trailer???!!!! Good luck at the track this weekend.
PostPosted: Fri Aug 08, 2008 5:43 pm
:lol: I was wondering if someone would catch that. I just moved the empty trailer around and loaded the truck. The Nissan doesn't like puling the empty trailer...
PostPosted: Fri Aug 08, 2008 5:48 pm
I was going to say hope the track wasn't very far from you if you had to use the Nissan to pull the trailer. Looks like a load for the old truck.
PostPosted: Sat Aug 09, 2008 12:24 am
Well, the results weren't what I hoped for. The weather apparantly screwed the lights, so after a 3 hr delay, we decided to say the heck with the time slips, let's hand flag.
1st pass, the brakes wouldn't hold. It's pretty common for the LUVs calipers to stick, I pulled both of mine and got them back up to snuff earlier, but the bleeding job was not good. SO, I came back around and we bled them.
2nd pass, the brakes were OK, so I trie to do a burnout, I added an electric shift solenoid, but I didn't hook up the wiring, for some reason, it kept kicking in with the 3 step, but it's not powered up, came back around and took it out.
3rd pass, hooked hard, left GREAT! :( No high gear...
All in all, pretty much what I expected. It hooked good even with the crappy track prep, so I might get it to hook with the fogger out of the gate, whenever I pull the tranny and replace the clutches...
PostPosted: Sat Aug 09, 2008 12:26 am
Below is a pic of 2 of the local guys I run with. The green one is another stepside LUV and the silver car is a carbuerated LS1 drag radial/ stock suspension car that is pretty stout when the kits come in...
PostPosted: Sat Aug 09, 2008 8:52 am
Doesn't it suck having problems at the track. I know what that is all about but that is part of racing. Keep us posted.
PostPosted: Sat Aug 09, 2008 11:47 am
And your budy with the Green truck is not a member because ...............................
PostPosted: Sat Aug 09, 2008 4:41 pm
can you get a better pick of the green truck and ill add it to the collection on my SmugMug site, thanks... that will make it an even 325 and still growing :lol:
well at least the track day wasn’t a total lose, you found out some of the problems and i am sure you’ll do better next trip... keep up the good work. luv the truck
PostPosted: Sat Aug 09, 2008 9:07 pm
That was my exact thought too when I seen the pic. :?:
PostPosted: Sat Aug 09, 2008 10:19 pm
There are at least 7 LUV's local to me, all of them are drag trucks, none of them have accepted an invitation to join. Most of them claim to not know how to use a computer...
And Ctmndu, I actually took a close up just for you, but the pic came out too dark. Maybe next time...
PostPosted: Sat Aug 09, 2008 10:29 pm
ok thanks...
PostPosted: Sat Aug 23, 2008 5:24 pm
I managed to pull the tranny, I hate working on my own stuff...
PostPosted: Tue Sep 02, 2008 12:07 am
Well, in between rain squalls from Gustav, we tore down the tranny. The valve body mounting bolts worked loose and it blew the gaskets. Loss of fluid pressure wiped out the Kevlar band and the high gear clutches and seals. Looks like all that's needed is the above mentioned parts and some Star-loc washers...
