It is currently Tue May 26, 2026 9:25 pm
PostPosted: Mon Jun 23, 2003 8:25 pm
Can I see a pic of a 80 LUV carb with air breather, and without breather... Mines never ha done, and I bneed to figur eout how it goes so I can rig oen up... thing is sucking to much air
PostPosted: Tue Jun 24, 2003 7:01 am
PostPosted: Tue Jun 24, 2003 6:34 pm
What holds the thing on there is no center hole on my carb?
PostPosted: Tue Jun 24, 2003 6:56 pm
it held on around the lip of the carb and there's 2 bolt holes on the valve cover. you can see the holes if you look closely 8)
The stock airfilter box clamps around what I think is the air horn :?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Jun 24, 2003 7:03 pm
DO any of you knwo if one of those little 5 or 6 inch crome ones will work, if I plug the vac lines off?
Here is a pic of what I have. not as puryt as the one above.. but i'm working on it.
PostPosted: Tue Jun 24, 2003 8:34 pm
i got a stock 1.8 air cleaner the you are welcome to have if you come and get it. also got a few other 1.8 parts you can have they are just takeing up space in the garage.
PostPosted: Tue Jun 24, 2003 8:41 pm
What town are you in exactly?
PostPosted: Tue Jun 24, 2003 9:08 pm
rutland
zip code 45775
PostPosted: Tue Jun 24, 2003 9:36 pm
Do you know if you are close to the vinton county 4wd and atv trails? If so, i'll be headed down that way sometiem soon
PostPosted: Tue Jun 24, 2003 9:53 pm
dont know about the 4x4 trails but i aint far from vinton and vinton aint that big :lol: let me know when
PostPosted: Tue Jun 24, 2003 9:58 pm
ok, I guess you are real close....... here is a mao
the trails are the star...... i see rutland on the map. I also see zanesville at the top, which is where I am
here is a close up of where the trails are
PostPosted: Tue Jun 24, 2003 10:04 pm
yep probaly about 45 min away......
PostPosted: Tue Jun 24, 2003 10:06 pm
I'm not sure when I'm headed down that way, but I'll give you a hollar when I do, and I'll stop by if you still got the parts, heck I migth stop buy even if you dont, just to bullshit with ya
PostPosted: Tue Jun 24, 2003 10:08 pm
cool....ill pm ya my phone number....gimme a buzz 8)
PostPosted: Wed Jun 25, 2003 6:49 am
i plan on meeting a fellow luv owner in 2 months when i go to cincinnati. we've talked a couple times over email. he told me his forum name but i forgot. :D
