It is currently Wed May 06, 2026 2:53 pm
 Post subject: LUV/Isuzu transmissions
PostPosted: Thu Jun 05, 2008 9:38 pm
Hi all,
I posted questions in another thread trying to get tranny info: viewtopic.php?f=6&t=17135
I got part of the answer, but before I got back to reply the thread was locked. I had already done a pretty thorough search on this forum, plus Oz Gemini, plus 3 other Isuzu forums, and checked with 4 online transmission parts vendors. Haven't yet found out the exact model of 4 speed transmission in the early LUV, or exactly which tranny may be the later.
Some say early uses MUA, others say later uses MUA. Some say early is MSG, others say later is MSG. Another claimed the early trans is an MUA-4, later is MSG-4. No help.
As mentioned in the other thread it's the early '72-'75 engine with intake/exhaust both on driver's side. Looks like I'll be stuck with this trans, but it's in good shape. For long term use I'd really like to know exactly what model transmission this is, so I can get correct parts if needed. Not sure if bellhousing flywheel, input shaft, pilot bearing, throw-out, or exactly what may be different from the later tranny installations. Accurate info on this application would be appreciated if you have it, thanks!
JimmieD
PostPosted: Sat Jun 07, 2008 2:55 am
MSG is the earlier of the two you mentioned.
The MUA is from behind a 2.6L and it is the later gearbox and considerably heavier than the MSG. I do believe that you could get this in a LHS starter model from behind diesel engines. You definately can with the MSG box from behind a C190 and C223.
You can also swap the front housing of a MSG gearbox over. So if you cant find a 5 speed with the starter on the LHS you can use the housing off a 4 speed and put that on the front of a RHS starter 5 speed.
Bob.
PostPosted: Sat Jun 07, 2008 3:19 am
Thanks, RodeoBob, that's a big help! Also helps me gather up parts ahead of time. Severely limited income from here on out so always best to pick up stuff before I need it. Thanks!
PostPosted: Sat Jun 07, 2008 5:08 am
I emailed someone i know to find out what the real early box is called. I was told once but i forget.
It has reverse gear next to first. As opposed to the MSG box which has reverse gear next to 4th.
Bob.
PostPosted: Sun Jun 08, 2008 12:05 am
Uh oh, here we go again....
Mine has reverse back and to the left, next to 2nd gear! Maybe not MSG or MUA. Like I've said, confusing.
PostPosted: Sun Jun 08, 2008 10:57 pm
He is not sure what they are called but is going to find out.
Apparently theres 2 or 3 different early boxes.
Bob.
PostPosted: Fri Jun 13, 2008 9:27 pm
Thanks for the update and going to the trouble for me! I got a PM from one of the guys with some info and will follow that up also.
PostPosted: Fri Jun 13, 2008 10:29 pm
Australian LUV Guru
It may be a MSE
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Jun 14, 2008 12:21 pm
Yep thats what came back to me.
MSE
Beat me to it.
Bob.
PostPosted: Sat Jun 14, 2008 4:31 pm
Okay, thanks guys! Now, help the comprehension challenged: MSE what? Isuzu MSE, Aisin MSE, any clues to track it down? I'll try to search the net in the meantime.
If I didn't mention, I'm building a rig to keep. Changing tranny is no problem, or stocker will work fine. Either way I'd like to know what will bolt in to replace, that's good and is available, or what to do for future parts for this chunk. Thanks for the help!
PostPosted: Sat Jun 14, 2008 4:42 pm
Okay.
1.What are you building?
2.Is there a major reason for sticking with that particular engine?
Contrary to my title I am no LUV guru by any means,I learn something new everyday here.
But from my understanding the newer Isuzu engines are much better and you have more drivetrain options.
PostPosted: Sat Jun 14, 2008 5:43 pm
As for 'what' I'll try to post some pics when it's done.
Checked on the MSE trans and got a hit at Wikipedia:
http://en.wikipedia.org/wiki/Holden_Gemini
Also used in 1st gen Holden Gemini TX, reverse is indeed over to left and back!
PostPosted: Sat Jun 14, 2008 5:46 pm
From this site:
http://www.holdengemini.net/tech_au_gemini.php
it sounds like the tranny is also called an M20, just to confuse things more.
PostPosted: Sat Jun 14, 2008 9:05 pm
TRY?
PostPosted: Sun Jun 15, 2008 2:49 am
JimmieD wrote:
From this site:
Nah that would just be on the 'Australian" General Motors Holden compliance plate. Manual 4 speed transmissions were called M20's in all cars. Close ratio gearsets got it M21, the Muncie rockcrusher was M22. The 5 speed was M72 or something silly like that.
MSE or MSG they were both M20 on the compliance plate AFAIK.
Its an isuzu MSE.
Bob.
PostPosted: Mon Jun 16, 2008 7:51 pm
Thanks again!
