It is currently Sat Mar 21, 2026 1:40 am
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Mar 17, 2008 3:17 pm
I wanted to compile a list of everyone that has done a 4.3 V6 swap so when I find a LUV I will know who to go to for help. So stand up and be heard.
Also If you have pics of the swap please post them or if you have already have done so please post a link. Also any advice would be nice so if you have the time list what you can.
Thanks
PostPosted: Mon Mar 17, 2008 3:43 pm
im 1 working on it .
PostPosted: Mon Mar 17, 2008 10:11 pm
i didnt do mine but mine has one and i can take pics of any thing needed
No luv right now =(
PostPosted: Mon Mar 17, 2008 10:38 pm
I've been trying to Google for the main website for Hooker for the trans and motor mounts for a 4.3L. Does anyone have that website?
PostPosted: Tue Mar 18, 2008 8:33 pm
I dont think Hooker actually has a website....
But if you go through Holley or http://www.holley.com/index.asp?division=Hooker
Thats about as much as I could ever figure out.
PostPosted: Sat Mar 22, 2008 6:53 am
I am just getting started on that swap myself.
I have the motor pulled and ready to fix up. you suggested to me to change out the manifold
rather than plate it for carburater conversion, and I thank you for that advice.
I am also swapping in Toy axles. I will keep you posted It will take alittle time to complete, I have a lim ited budget for the project. It will also be my first swap.
Ill be watching this post for fellas that can help me with mine...
PostPosted: Sun Mar 23, 2008 2:11 pm
I know you would be a lot happier with the intake swap when it comes to power. Also, check around, there are a few guys swapping S10 stuff, might work better than the Toyota stuff.
PostPosted: Sun Mar 23, 2008 6:52 pm
A trooper rearend off a V6 is strong enough and saves having to do the lug bolt change. Toyota yields the same. Anybody got a website or address for the Hooker engine swap kit yet?
PostPosted: Mon Mar 24, 2008 8:09 am
Pretty sure he means puttin in the toyota front axle.
Bob.
PostPosted: Tue Mar 25, 2008 2:57 pm
I keep forgetting that some of the people here are into 4wd.
PostPosted: Thu Mar 27, 2008 6:14 am
Who makes motor mounts to do this swap? Also is it a all bolt in affair or do the have to be welded?
PostPosted: Thu Apr 24, 2008 10:06 am
Any updates from those of you doing a 4.3 swap?
PostPosted: Sat May 17, 2008 3:31 am
i did a 4.3 engine in mine and as far as mounts and small stuff youll have to fab it your self,it wont be easy. i highly recomend the edelbrock intake for the 4.3, i had to go with a cast iron intake due to emmissions reasons and im so disapointed in my 6.
i started out with nothing and still have most of it left...
PostPosted: Sat May 17, 2008 2:32 pm
Image no fit :cry:
monday stock will be coming out. :cry: but it gets like 18mpg now hope it gets better with
4.3l
PostPosted: Sat May 17, 2008 5:30 pm
I am planing a 4.3 swap. I do have a good start, the truck had a V-8 in it before.
PostPosted: Mon May 19, 2008 10:47 am
Here is an idea that may make it where you can use the hooker mounts instead of fabing and upgrade to a V8 later on. http://www.speedwaymotors.com/p/7899,405_1988-2000-S-10-Engine-Swap-Kits.html
Speedway motors also has alot of custom motor mount options for V6 and V8 application http://www.speedwaymotors.com/m/405_Engine-Motor-Mounts-Conversion-Kits.html
PostPosted: Mon May 19, 2008 11:09 am
Also there is this option
http://www.speedwaymotors.com/p/3273,405_Small-Block-Big-Block-or-90-V6-Chevy-Crossmember-Mounts.html
and they carry a removable tran mount / crossmember
http://www.speedwaymotors.com/p/3279,443_Straight-Tubular-Transmission-Mount.html and the price is not bad at $34.99 for a bolt-in / weld-in trans mount that is removable, but I am not sure if a Luv frame is wider than 38".
PostPosted: Fri May 23, 2008 7:58 pm
the stock 1 is out
PostPosted: Wed Jun 04, 2008 3:22 pm
V6 is in get pics soon
PostPosted: Thu Jun 05, 2008 7:36 pm
Looks like the 4.3 that I have and a small block have different mounting points for the motor mounts, the V-6 is farther back. If anyone has pics of the motor mounts welded in the LUV please post.
