It is currently Fri Apr 03, 2026 2:38 am
 Post subject: Front Drum Brakes
PostPosted: Wed May 29, 2002 7:20 pm
g'day i have front drum brakes on my 77 chev luv and i cant figure out how to adjost them and because of that the pedal goes close to the floor so does any one no how to adjust them???
PostPosted: Thu May 30, 2002 5:09 am
if it goes to the floor it could be a master cylinder problem, or you could have a leak in the system.
most drum brakes are set up to adjust when you press the brakes in reverse.
03Cobra
PostPosted: Thu Feb 20, 2003 10:10 pm
yeah could be a master cylinder issue.
PostPosted: Thu Feb 20, 2003 10:37 pm
I had the same problem with my drum brakes for years and i thought it was the adjusters. It's most likely that the front brakes need to be bled. The front brakes adjust automaticly when the brakes are applied.There's 6 separate wheel cylinders total on the truck(4 up front). I bought a brake bleeder hose with a check valve and bled everything! The pedal came back up and it had a solid feel to it. But i always had a cylinder leak spring up somewhere. Bleed the brakes, you'll be suprized to see all of the air, dirt and water thats pumped out of the system. If the fluid lines are contaminated with trash, the adjusters wont work. It's a goofy adjuster mechanism and it wont hold an adjustment if there's a fluid issue. I went thru this already with all new parts and it all comes down to clean brake fluid and no air in the system. Do this! It will only cost you a quart of fluid and i'll bet it fixes the problem.
PostPosted: Sun Feb 23, 2003 2:00 am
When i had front drums, my pedal always went close to floor when it was running, but when i shut it off the pedal was better. Turns out it was the vacuum booster.
