It is currently Sun May 10, 2026 11:14 am
 Post subject: fuel tank for 80 luv
PostPosted: Wed Apr 23, 2008 1:45 pm
Does anyone know where i can get a good gas tank for 80 luv ?
 Post subject: Re: fuel tank for 80 luv
PostPosted: Wed Apr 23, 2008 3:17 pm
where do you live?
PostPosted: Wed Apr 23, 2008 3:26 pm
East TN Johnson city area
PostPosted: Wed Apr 23, 2008 6:35 pm
Ive got one for an 80 that you can have. Im in Salisbury NC, just North of Charlotte
PostPosted: Fri Apr 25, 2008 3:09 pm
Hey bugman that sounds good it will proable be about 2 wks before i am back in town and can come and get it.I drive a semi and am out on the road workins is this ok
PostPosted: Fri Apr 25, 2008 7:53 pm
Well if you come through oklahoma I have one too.... :wink:
PostPosted: Sat Apr 26, 2008 10:01 am
Just a suggestion:
I have an 80 Luv 4x4. The truck had been sitting for a year when I bought . I took my tank out had it boiled out and then put a sealer inside. It stops the rust, and suppose to last 20 years. You may want to consider this if you get another stock tank. 8)
PostPosted: Sat Apr 26, 2008 7:09 pm
yeah ZAne i'm going to do something to try to protect it. I never have heard of that boiling thing but i will look into it maybe what I need
PostPosted: Sun Apr 27, 2008 1:06 am
I took my gas tank to a shop that boiles out radiators. They can do the same for gas tanks. It just cleans out the inside really well. Then the sealer is put in.
PostPosted: Sun Apr 27, 2008 9:40 am
You can also clean and coat the tank yourself. It requires some effort, but if money is an issue this method works well.
Take the sender out, and fill the tank with water. Empty the water from the tank, and refill it a couple of times to get most of the big junk out. Clean it out well, spray the sprayer in there, wiggle the tank, etc. Then cover the sender opening with something fairly rigid (a coffee can lid, etc.). Drain the tank but leave a gallon or so of water inside, drop a 6' long piece of chain in the fuel filler pipe and then roll, and turn the tank. The chain will scour a lot of junk off. It will need to be turned upside down, as most of the flakes and junk is on the top (condensation causes this). Roll it and swish it and whatever, until you're satisfied most of the crap has been scraped off. You might want to change out your gallon of water a couple of times. Tip it up and let the chain slide out, take the cover off the sender opening, then rinse it again and let it air dry.
DO NOT use a hair dryer or torch to try to dry it quicker! :onfire:
You can buy a gas tank coating kit from Eastwood (I think) or JC Whitney and then just follow the directions to put a new coating in the tank. http://www.jcwhitney.com/autoparts/Prod ... =fuel+tank
Total cost about $50 and a couple of sore arms...lol...
PostPosted: Sun Apr 27, 2008 10:36 am
Here's a great way to go...http://www.por15.com/prodinfo.asp?grp=FTRK&dept=11 I used por15 to restore the floor on my LUV, and it was an excellent product.
'78 1.8L 4-speed Fleetside
Image Image
Users browsing this forum: Bing [Bot] and 29 guests
