It is currently Thu Jun 25, 2026 11:24 pm
 Post subject: lt1 6 speed
PostPosted: Sun Mar 30, 2008 3:26 pm
has anyone swapped a lt1 and 6 speed into a luv? if you have is it more difficult mounting tranny and engine compared to a regular 350 th350 swap?
6.0l ls1 swap th350
 Post subject: Re: lt1 6 speed
PostPosted: Wed Apr 02, 2008 5:50 pm
I'm not for sure, Can't speak on the behalf of everyone. However I haven't seen one. The engine it self would use the standard headers (You will need O2 censor) and mounts as the stander SBC swap. Not completely for sure, but you should be able to use the transmission mount as well. However due to the shifter placement (at nearly the tail shaft) and shape they will have to be modifications done to your transmission tunnel.
8) I say go for it! shouldn't be much harder then the standard swap. The transmission tunnel will probably be your largest issue of modifying.
PostPosted: Wed Apr 02, 2008 7:47 pm
do it.i think it would be cool
PostPosted: Wed Apr 02, 2008 11:05 pm
well im open to a bunch of different swaps at this point. I am working on my second luv! sold the first :( but i want to be fast around town and on the interstate. im looking into ls1 swaps to or maybe a 5.3l chevy who knows!lol
6.0l ls1 swap th350
PostPosted: Sun Apr 13, 2008 5:26 pm
do the 5.3, then let me know how you did it!!
PostPosted: Sun Apr 13, 2008 7:32 pm
I actually looks into it there cheap motor and trans for under a 1000 on ebay. just dont know about wiring fuel gauges etc...lol
6.0l ls1 swap th350
PostPosted: Sun Apr 13, 2008 8:02 pm
current performance or painless wiring are two stops to make for a wiring harness. Painless makes stand alones for pretty reasonable. I always wanted to do an ls1 and a 6 speed but those go for some pretty good coin
PostPosted: Mon Apr 14, 2008 5:19 pm
I did a 5.3 swap into a 1998 s10 with current performance harness, it worked out pretty good, I've use painless in the past and had all kinds of problems.
PostPosted: Mon Apr 14, 2008 6:58 pm
do you have the website or contact info for the wiring harness.
6.0l ls1 swap th350
PostPosted: Wed Apr 16, 2008 11:44 am
http://currentperformance.com/
looking at his site, he also does lt1 wiring
PostPosted: Thu Apr 17, 2008 8:39 am
well i think i have made up my mind. goin for the 5.3l swap in a couple of months. just have to decide on manual or auto
6.0l ls1 swap th350
PostPosted: Thu Apr 17, 2008 9:04 am
good choice, I love mine in my s10!! heres a few pics for ya.
PostPosted: Thu Apr 17, 2008 1:00 pm
wow nice. auto? Did you get your motor with a harness and computer then have it modified or did you by a complete harness. Also do you run all the emisions stuff and how about top speed limiter is yours modified? whats yours out of looks to be out of a truck with the tall intake
6.0l ls1 swap th350
PostPosted: Thu Apr 17, 2008 4:51 pm
its out of a 2002 suburban, I looked on craigslist for the motor, no harness, I just bought one from jared, all the emissions is there, it passed emissions testing in Texas, it was a 4cyl 5spd, but I converted to auto. all the gauges work, a/c works ( although not hooked up in the pic, but is now) it is a very fun truck, and for sale :ebiggrin
oh yea, speed limiter is set at 200 via HPTuners, I've been learning on this truck..
PostPosted: Thu Apr 17, 2008 8:21 pm
hope you dont mind me bothering you when i buy my motor. what guages do you run the ones outta the suburban?
6.0l ls1 swap th350
PostPosted: Thu Apr 17, 2008 9:34 pm
oh hows the truck run have you took it to the track or raced any quick cars its got to move being so light how much does it weight?
raced any vettes,cobras,transams,ricers?lol
6.0l ls1 swap th350
PostPosted: Fri Apr 18, 2008 6:00 pm
runs good, I've took it to the track once, open diff, so it spun off the line, but ran 14.8, I've surprised a few mustangs and ricers, no vettes though. I'm running all the factory S10 gauges, I had to adjust the fuel gauge reading in the ecm, but it works fine..its no bother..
PostPosted: Fri Apr 18, 2008 7:04 pm
i think im gonna put a limited slip 3.42 trans am rear end under mine. It should be pretty quick only weighing like 2500 pds compared to like a trans am ws6 that weighs 3500. gonna go for a hot cam too. does the guy that does the wiring program computers to?o I dont want any emisions stuff oxy. sensors map sensor etc. just motor and fuel!lol
6.0l ls1 swap th350
PostPosted: Fri Apr 18, 2008 11:10 pm
I think he does, I did finally put a limited slip diff in mine, just haven't been to the track since, but it does pull better on the street.
PostPosted: Thu Apr 24, 2008 6:12 pm
gah I just picked up a 6.0l outta a 2002 yukon gonna carburate it!! yeah :lol: :lol: :ebiggrin
6.0l ls1 swap th350
