It is currently Fri Mar 20, 2026 3:35 pm
 Post subject: 4.56 in a luv?
PostPosted: Thu Mar 20, 2008 1:49 am
is there an axle i can get the diffs out of. im looking for lower gearing. right now i can reuise bout 80mph fine but i want lower gearing for the climbing. im planing on 4link and coil over frotn and rear. conversion but i wnat to keep as much stock parts as i can. any body know where i can get like 4.56 or 5.?? gearing
 Post subject: Re: 4.56 in a luv?
PostPosted: Thu Mar 20, 2008 3:07 am
Australian LUV Guru
4x4 Luvs, Pups and Troopers use a 4.555:1
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Mar 20, 2008 4:50 am
My 1980 4x4 and 1978 automatic luvs had 4.10. My 76 manual transmission, 2wd luv has 4.56 gears.
PostPosted: Thu Mar 20, 2008 5:27 am
Australian LUV Guru
Here in Australia we had a 5.125:1 ratio :ebiggrin
PostPosted: Thu Mar 20, 2008 11:08 am
u should send me some ring and pinions :D
PostPosted: Sat Mar 22, 2008 12:03 am
Most of the 4x4 Luvs had 4.10 gears. If anything else was put under them, I haven't heard of them.
A lot of troopers had 4.55 gears.
Others here have suggested that the front differential from a mid-80s trooper is a bolt-in swap.
The rear-end can be adapted to go under the Luv. If you get one from a disk-brake trooper Isuzu 12-bolt), you will also have the advantage of 4 wheel disk brakes. There are other posts about bolting trooper differentials into Luvs.
Also, if you ever decide to use a locker, the Isuzu 12-bolt rear-end can take a locker. (Currently, no one makes one for the Luv differentials.)
You went there in that?!?!
PostPosted: Sat Mar 22, 2008 10:29 am
i bet the trooper axle is stronger to :twisted:
