It is currently Sat Jun 13, 2026 11:24 am
 Post subject: tire pressure
PostPosted: Sat Mar 15, 2008 10:37 pm
can you use tire pressure to help get the truck to run straight , it gets pretty wild when you lay into it , it always goes to the right , so i was curious whether i could play with the tire pressure and maybe help it run straight ? thanks in advance for any info
junkyard racing - we win with your old parts
 Post subject: Re: tire pressure
PostPosted: Sun Mar 16, 2008 12:51 pm
If you are talking at the dragstrip, yes you can help that to a certain extent. Also you can adjust the suspension. If you are talking about going down the road then it could alot of different things.
PostPosted: Sun Mar 16, 2008 5:21 pm
Yep at the dragstrip you want the tire pressure to be the same otherwise the truck will launch one way or the either.
PostPosted: Mon Mar 17, 2008 9:42 am
all the way through first and second the truck wants to swing to the right , this is on the street , and not with slicks , it has radials on it now
PostPosted: Mon Mar 17, 2008 5:39 pm
get a tire alignment. maybe thats it? :?
PostPosted: Mon Mar 17, 2008 9:48 pm
:signimsorry
PostPosted: Tue Mar 18, 2008 5:03 pm
Well if you are talking while spinning on the street through 1st and 2nd then you are a victim of he dreaded one wheel peel :D
PostPosted: Tue Mar 18, 2008 8:14 pm
it spins both tires
PostPosted: Thu Mar 20, 2008 2:47 pm
Well if you have a spool or welded the spiders and having the problem, you have one tire that is "biting" harder than the other one. This could be caused by the slapper bars being adjusted wrong or possibly a weak leaf spring.
PostPosted: Sat Mar 22, 2008 11:30 am
Mine moves to the right also . I have to move the wheel to about 2 o'clock . Besides that it spins just a bit sideways fine . Swap those radials for a tire with bite , that'll end your sideways trouble .
PostPosted: Mon Mar 24, 2008 5:53 pm
What type of supension are you running? Stock, Ladder Bar, Slapper Bars, 4 Link. All have some adjustments that can be made to help it run straight.
