It is currently Sun Mar 22, 2026 4:51 am
PostPosted: Sun Mar 16, 2008 1:59 pm
i need head work but i found a 1.9 gas engine from a pup i think its a G200? could i bold my manafold and header and tranny to the engine ?
PostPosted: Sun Mar 16, 2008 7:37 pm
should be a bolt in swap as far as i know.... drop it in and enjoy
PostPosted: Sun Mar 16, 2008 7:40 pm
Might want to take a look at the distributor in the 1.9, if it's there. Keeping the electronic unit (if so equipped) is a really nice upgrade. There are a couple of threads here on how to wire it up.
You'll need to swap out the oil pan, I think...
Good luck, let's see some pics of your new rig!
PostPosted: Sun Mar 16, 2008 7:42 pm
yeah i would swap the complete motor in including the alternator and the electronic ignition is it has it
PostPosted: Sun Mar 16, 2008 8:53 pm
It's a bolt-in swap except:
As nukeday said, the oil pan. Not because of the engine size but because of the 4wd. The oil pans on the 4x4s have a divit in them to clear the front differential. Your old oil pan will fit the new motor.
Depending on the engine, it might not have the threaded holes in the head for the air injection rail. I bought a G200, don't know what it came out of, and it didn't have the holes. From an 80s pup however, you should be OK.
If you use your existing intake/exhaust, etc., you won't see a real performance improvement, however if it gets your truck running, I'm sure it's worth it.
You went there in that?!?!
PostPosted: Sun Mar 16, 2008 9:12 pm
Aaron, trail_racer just did a 2x to 4x install with the engine I had...
viewtopic.php?f=24&t=16386
Might want to check with him, as far as any details on installation.
He's relatively close by too, not sure what condition his head was in on the engine he removed, but if you just need valves it might be worth checking in with him.
PostPosted: Thu Mar 27, 2008 3:44 pm
thanks
