It is currently Fri May 08, 2026 10:48 pm
Post new topic Reply to topic  [ 294 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 15  Next
PostPosted: Sat Feb 16, 2008 12:06 am
Well tonight we got the cab layin pinch, looks sick :smt078 Still gotta cut off the bolt holes on the fender(not a big deal), you can barely tell from the pics but the pinch is about 1/4"-1/2" from the cement because the floor isn't even :x Tomorrow we are startin on the bed mounts and if everythin goes well could be dropt as well
PostPosted: Sat Feb 16, 2008 1:00 am
looking good 8O
PostPosted: Sat Feb 16, 2008 7:52 pm
Got an early start today and heres the outcome, cut out bed crossmembers, made bed mounts and got the bed b/d 3 1/4" :smt045 Tomorrow I might go and get some sheet metal so I can section the bed and roll it under like the cab so everything will be even. Enough talk here are the pics....
little blurry
PostPosted: Sat Feb 16, 2008 8:25 pm
nice work!
PostPosted: Sat Feb 16, 2008 9:13 pm
Looks like alot of work. But is looking sharp.
PostPosted: Sat Feb 16, 2008 11:34 pm
Yes your right, a lotta work has went into it to get it to this point, not to mention that it has really only taken 7 days to get it to get it there!
PostPosted: Wed Feb 20, 2008 5:39 pm
Looks good.
PostPosted: Mon Feb 25, 2008 9:01 pm
Suspension has been on hold, my buddy was paintin his c10 this weekend. So I started on the sheet metal dash.....
Added round tubing to make it look even more old skool
Just need middle patched and everything is welded up
PostPosted: Sun Mar 02, 2008 10:25 pm
All welded up, I already have it smoothed, but w/o any pics at the moment, can't finish all the body work yet because I still gotta make a steel center console to the bottom of the dash after I section the tunnel for transmission and drive shaft
PostPosted: Tue Mar 04, 2008 6:28 pm
That is a interesting cup holder the you have in the center console. Is the console staying in the truck after the SFBD? Also is that a 2nd LUV in the right side of the garage?
PostPosted: Tue Mar 04, 2008 9:49 pm
Center console is gettin thrown out, makin a steel console that flows right w/the dash, I had another 79 Luv but it went to the junk yard after I stripped it all
PostPosted: Tue Mar 04, 2008 10:22 pm
Front bracket has been cut and dropped for the radiator, next is steerin then I'm blastin that frame at the body shop I work at so it'll be super easy to finish up welds, make battery trays, and a few more gussets. Meanwhile, got the body work pretty much done on the dash, and started grindin/cuttin on the firewall to smooth it out
PostPosted: Wed Mar 05, 2008 1:39 am
PostPosted: Wed Mar 05, 2008 8:37 pm
Looking pretty sweet. Wish I had that kind of talent!!!
PostPosted: Wed Mar 05, 2008 9:32 pm
me too 8O
No luv right now =(
PostPosted: Wed Mar 05, 2008 10:13 pm
Lookin good! 8)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Mar 05, 2008 11:01 pm
Thanks guys, I'm really bustin to get this ready for paint by the beginnin on June, still have a long road ahead but gettin closer and closer every day
PostPosted: Thu Mar 06, 2008 5:59 am
The dash looks really good. How much fabrication was there? Did you just fill in the empty spaces and smooth it out, or is that a completely new dash?
PostPosted: Thu Mar 06, 2008 10:23 pm
Its the stock Luv dash, tore it completely down and welded all the holes shut, added round tubin to give it a hot roddish look
PostPosted: Sat Mar 08, 2008 1:16 am
the dash is looking very nice, great job
