It is currently Fri Apr 19, 2024 2:38 am
Post new topic Reply to topic  [ 59 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Jan 13, 2008 5:52 am
Australian LUV Guru
Ok, so i started stripping down my 85 4x4 Trooper today and i noticed that it has nice ventiled disc's. Took a closer look and it looks as though the axel stubs are identical to my 80 4x4 Luv. Going to try swaping the Trooper brakes ito the Luv when i get a few hours spare, i'll take a few pics and post the results. Maybe im wasting my time, this swap seems to easy. Has anyone done this before?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun Jan 13, 2008 4:27 pm
http://forums.luvtruck.com/viewtopic.php?t=15729
PostPosted: Sun Jan 13, 2008 9:25 pm
Australian LUV Guru
Ok had some spare time to try this Trooper to Luv brake conversion. Took the Luv brake caliper off and tryed the Trooper caliper, sucess :D the caliper bolted up, even the flexible fluid line bolted up to steel line perfect.
Image Luv caliper Image Luv caliper
Image Trooper caliper Image Trooper caliper
The Trooper calipers have a larger brake pad surface area than the Luvs, next step is to fit the vented Trooper disc to my Luvs hub.
PostPosted: Sun Jan 13, 2008 9:36 pm
Thanks for the pics of this, this looks like a great option for my V8 truck. Better braking for the about the same cost as Luv components is a big plus. :D
Do you know if this caliper/rotor setup will work on a 2x?
PostPosted: Mon Jan 14, 2008 2:57 am
Australian LUV Guru
I cant see/think of any reason why this setup wouldn't work on a 2wd aswell.
PostPosted: Mon Jan 14, 2008 7:23 am
Im 99.999999% sure it will work on a 2x4. ive got all the bits here but havent actually done it. The steering linkages could possible be different. The 2x4 Luv has a central adjustment with a fixed rod end. The later ones 81~ have fixed center drag link and adjustable rod ends. The steering arm on the spindle could be a different length height affecting geometry. Perhaps im being a little over cautious.
Make sure the master cyl is a disc brake one.
I havent got to mine as im contemplating what to do with the master cyl and booster. Plus ive got way too many jobs to do first.
What im wanting to do is use the 88~ discs as they are bigger again but that is when they changed the lower balljoint to point up instead of point down and the spindle wont fit.
Bob.
PostPosted: Mon Jan 14, 2008 10:50 pm
On the 84-86 Troopers the caliper brackets bolt up and the disk should bolt to the LUV hub, 2wd or 4wd. No need to swap spindles. The hubs look like they could be made to work with a little figuring on the inner wheel bearing seal, in case someone decided they wanted to put auto locking hubs on a LUV for some reason.
On the 88 and up Troopers I don't know about either the calipers or discs fitting anything on the LUV, so you would have to look at the spindles and ball joints, but I doubt it would be easy to get it bolted up and get the geometry right.
PostPosted: Tue Jan 15, 2008 3:42 am
Australian LUV Guru
I'll be bolting the trooper disc 2 my Luv hubs so can keep my aisin manual locks. Im also going to use my Luv calipers for a while till i get a good deal on rebuild kits for the trooper calipers. All the auto parts near me have quoted me $50 a kit, thats a ripoff for only 1 rubber ring and 3 small rubber dust boots. 8O
PostPosted: Tue Jan 15, 2008 8:47 am
You need to keep the caliper thats matched to the disc.
The pads can fall out or just flat out wont fit in.
Dont mix and match the calipers unless your sure you know what your doing.
Try a place called brake west, McIntyre rd in sunshine north. I get my stuff off them and the prices are pretty good.
Cheers, Bob.
PostPosted: Wed Jan 16, 2008 3:23 am
Australian LUV Guru
The Luv caliper should be fine used with the Trooper disc. The Trooper ventilated disc is the same diameter and only a little thicker than the Luvs disk.
PostPosted: Wed Jan 16, 2008 1:44 pm
Banishment Pending
interesting...my Luv already has the vented discs...wondering if maybe they came factory for US spec 4x4's?
PostPosted: Wed Jan 16, 2008 11:22 pm
Only if you have got half worn pads in the luv calipers. If the discs are thicker you will have trouble stuffing a full thickness new pad in.
Isnt is something like 12mm for the solids and 20mm for the vented.
Bob.
PostPosted: Thu Jan 17, 2008 3:48 am
Australian LUV Guru
My solid Luv disc's measure in at 18mm, and they were machined 12 months ago when i fitted new pads. The Trooper disc's i hav measure in at 19mm with a minimum thickness stamped on the disc of 16.6mm. Also took a good look at the Trooper pad vs the Luv pad, the Trooper pad is almost identical to the Luv, the Trooper pad is 2mm wider/longer. I'll be using the Luv calipers, there is little to be gained using the Trooper calipers.
Image Image
PostPosted: Thu Jan 17, 2008 8:39 am
Fair enough.
Ive never paid any great attention to solid 4x4 discs.
As far as i am aware the 2x4 discs are no where near that thick.
Bob.
PostPosted: Thu Jan 17, 2008 9:29 pm
My 79 4x4 has its original rotors. They're solid.
OzLuvTrucker, have you ever weighed the rotors? Are the vented ones lighter?
As far as you can see, are they fully compatible? If so, I'm headed for the pick-n-pull.
Thanks.
You went there in that?!?!
PostPosted: Thu Jan 17, 2008 10:32 pm
Australian LUV Guru
The Trooper rotors feel half the weight of the Luvs solids. Ive just completed the conversion and theyre totally compatible. Its so simple i dont know why i hav'nt seen this done before.
Step 1 remove hub from Luv.
Step 2 unbolt Luv rotor from hub.
Step 3 bolt Trooper rotor to Luv hub.
Step 4 fit hub& rotor back on Luv.
PostPosted: Sun Jan 20, 2008 10:00 am
i think the trooper caliper would be better than the luv. the trooper has floating style pins with rubber boots. the luv has shims and plate that are exposed to mud,dirt witch equals sticking calipers.
PostPosted: Sun Feb 03, 2008 6:56 pm
will the lines cross, like with the same threads r what. i mean i could just buy new rotors and calipers and bolt them on?
PostPosted: Sun Feb 03, 2008 8:08 pm
They should, they are both japanese so everything should be metric.
Bob.
 Post subject: Re:
PostPosted: Fri Feb 22, 2008 10:24 pm
