It is currently Wed Jul 08, 2026 12:41 am
PostPosted: Mon Jan 07, 2008 8:25 pm
Does anyone know If I can use an Electric water pump from an older model 350????
PostPosted: Thu Jan 10, 2008 6:42 pm
Really nobody..... Nothing?????
PostPosted: Fri Jan 11, 2008 12:54 am
Not really enough info to go on is most likely the cause of the lack of response. I'll take a shot though. A Vortec has a reverse rotation system from the older models, so if you are thinking of using the pump with the electric motor built in the pump, then no, if you are thinking of using the Moroso type pump drive that uses the belt, then yes.
PostPosted: Fri Jan 11, 2008 1:29 am
Shogun makes a water manifold that replaced the water pump and the pump is a remote pump that is inline with the radiator hose, that will work also.
PostPosted: Mon Jan 21, 2008 10:46 pm
Call the tech line at Meziere Enterprises
They will have a solution for you.
http://www.meziere.com
Users browsing this forum: Bing [Bot] and 37 guests
