It is currently Fri Jun 12, 2026 4:04 pm
 Post subject: nitrous
PostPosted: Sun Jan 06, 2008 6:38 pm
I ve been debating putting nos on my truck,what are the down falls to nos,and is it complicated to set up and use ? what kind of system would be best
junkyard racing - we win with your old parts
PostPosted: Sun Jan 06, 2008 7:00 pm
Upside, more power, downside, bottle runs out. Best bet is to build your engine to use twice as much NOS as you are planning to run, cause you will up the jets. If you have already built the engine or are pretty much stock, then stay under 150hp, A plate system is fine for carbeurated systems at 250 and under, a fogger system will generally let you get away with a bigger initial hit as it usually is a softer hit and doesn't shock the tires as hard as a plate. I have had good luck with NOS systems and Wilson Nitrous Pro-Flow systems, heard good things about ZEX as well. Edelbrock systems have finicky solenoids, IMO, but they work well when they are working.
 Post subject: nos
PostPosted: Sun Jan 06, 2008 8:00 pm
All the guys I run with use nitous.....Make sure you use forged pistons.Nitous is ok but like stated above BOTTLES RUN OUT....and that sucks .Once you use it you will find out why they call it dope.lol
PostPosted: Mon Jan 07, 2008 11:55 pm
what kind of process is it after you install it ,i i'm sure you don't just hook it up and start sprayin . I was thinking about a 150 or a 200 shot, i'm runnin a pretty nasty 383 stroker,and i really wanna get in the 10s :D
PostPosted: Tue Jan 08, 2008 1:12 am
Never spray until you have everything up to snuff on just motor, if it's not right before you spray, it will surely be worse. Over 150 shot, you need to have your ring gaps open a little larger than normal, as the shot goes up the ring gaps tend to butt, not good. Retard the timing 2 degrees for evey 50 hp increase, and go to a colder plug, also close the spark plug gap up to .035.
PostPosted: Wed Jan 09, 2008 9:25 pm
I bought the complete NOS Super Power Shot and it comes pretty much turnkey. It comes with installation instructions and setup that a 5yr old can follow. Although really fine tuning a nitrous setup I would consult someone with experience. There is a fine line between "HOLY SHIT" and "BOOM" :D
PostPosted: Thu Jan 10, 2008 6:28 am
I run the NOS cheater set up to 150 . Terry is correct have your tune on motor right . This may seem extreme , but i put mine on a chassis dyno and got the A/F ratio right . Bottle pressure and timing are key . I tend to go a little high and purge down to just above recomended and when I go through the traps I'm just below the recomended . I had a local nitrous guru help me set the fuel pressure and i will add 110 octane when avalible to be safe . My current combo has 195 passes on it , so i'm a believer in good set up and balancing the motor . @ $40 bucks a bottle it can get expensive . If you race with it you need spare bottles .
PostPosted: Thu Jan 10, 2008 7:13 am
Oh , and my junk is a 2 bolt with cast crank .
PostPosted: Thu Jan 10, 2008 7:27 am
hotrod yours is junk by no means, i'm starting to lean to the nos side a little bit so this info is good for me,but that's after i get my set up right.i will be at HMP next friday hotrod if the weather is good so come on out if ya can and play. :D :D
PostPosted: Thu Jan 10, 2008 10:24 am
Don't mean to highjack , but I got'r jacked up changing the converter again . Prolly be @ HRP sunday .
PostPosted: Thu Jan 10, 2008 10:34 am
AGAIN sorry to hear that. 8O
 Post subject: hrp
PostPosted: Thu Jan 10, 2008 4:41 pm
Hey hotrod I might be out there sunday drivin my friends luv.
Users browsing this forum: Baidu [Spider] and 13 guests
