It is currently Sat Jun 27, 2026 10:56 pm
 Post subject: Transfer Case
PostPosted: Tue Dec 04, 2007 10:48 am
Well i am geting a new clucth and the Tran e and the trans fer case rebuild and the shop called me and said that the gear oild in the transfer case had turn to raw oil just crued oil again
So i thought i would let ya kow that have never chaged the fluid in your transfer case u might want to
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sun Dec 16, 2007 5:57 pm
how do u change the oil in the tranfer case and what do u change it to?
PostPosted: Wed Dec 26, 2007 10:14 pm
just normal gear oil
79 4x4 1.8 liter
PostPosted: Thu Dec 27, 2007 9:16 am
The transmission and transfer case use 10w30 motor oil.
PostPosted: Fri Dec 28, 2007 3:44 am
Australian LUV Guru
Use the same oil as you use in your engine in the gearbox.
1980 4x4 KBD40 ISUZU/Chev Luv
