It is currently Mon Feb 02, 2026 2:22 pm
 Post subject: BALL JOINT REMOVAL
PostPosted: Mon Aug 20, 2007 10:17 pm
Australian LUV Guru
Can someone tell me what size socket i need to undo the large nut holding the top ball joints in. Thanks.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Tue Aug 21, 2007 4:39 am
X 2 and a bump
PostPosted: Tue Aug 21, 2007 7:00 pm
Im sure its probably metric...so I know I will get a beating for saying this...
I used a 2 1/4" socket, and it worked fine.
PostPosted: Tue Aug 21, 2007 8:34 pm
Australian LUV Guru
Cheers Hotrod & Erronisme
PostPosted: Tue Aug 21, 2007 9:25 pm
Pour a VB for me :D
PostPosted: Wed Aug 22, 2007 4:52 am
Thanks , this project will be attempted next week .
PostPosted: Thu Aug 23, 2007 5:08 am
Australian LUV Guru
2 1/4 socket on eBay AU$65 +$9.50postage
http://cgi.ebay.com.au/Teng-Tools-1-Dri ... dZViewItem
Cutoff disk for 9inch grinder AU$5 at any hardware store
:? mmm I wonder what i should do
PostPosted: Thu Aug 23, 2007 7:01 pm
well...do you plan on putting the new nut on there?
PostPosted: Fri Aug 24, 2007 9:09 pm
Yep, when I redid mine on I switched to disc brakes I had to grind it into. it was hell trying to break the old nut loose.
 Post subject: ball joint
PostPosted: Sat Aug 25, 2007 6:08 pm
I used a air chisel with a flat chisel tip and had to unscrew the nut with the air chisel, or chisel a spot into the nut all the way to the treads.
PostPosted: Mon Sep 10, 2007 2:15 am
pipe wrench????
OzLuvTrucker, ive got one of my new ones rolling around on the floor of my spacecab. For that exact reason, a tool to undo the old ones to put the new one in.
You could weld something to the old one and get it out. Clean up the threads and screw the new one in.
Or if your handy with a welder you could make a ring socket. Not sure how good that would be if i rememebr right the BJ is 12 hex.
If your still stuck on this give me a PM.
Bob.
