It is currently Mon Feb 02, 2026 6:43 pm
PostPosted: Thu Jul 12, 2007 9:49 pm
it is working great for me, anyway, take a shitty flat screwdriver and break off the plastic handle. cut a notch about 1 inch down the middle of the blade end of the screwdriver. insert into 1/4 inch die grinder, fold up a piece of emery cloth and stick it in the slot. bend the emery cloth a little bit to get it into the port. press trigger and let the fun begin! oh be sure to grind off the little tabs on the shaft of the screwdriver that held it in the plastic. they get in the way of the grinder chuck.
(PLATINUM STREET RODS)
Deming, NM
PostPosted: Thu Jul 12, 2007 10:31 pm
A wad of the aluminum mag wheel polish that looks like cotton (a couple of different maufacturers make it) will really slick it out. use it to final hone after you get it close with the emery cloth. we use it to ahem, blueprint, our cart carbs. :lol:
PostPosted: Fri Jul 13, 2007 2:36 pm
hey sweet! thanks for the tip!
Deming, NM
PostPosted: Fri Jul 13, 2007 6:49 pm
No prob... :lol:
 Post subject: Port Matching
PostPosted: Mon Jul 16, 2007 12:48 am
A lot of guys lay the gasket over the head, intake and exhaust, slide them on the stud to line em up mark the areawith a white grease pen and take offthe restrictiver area. Smooth the transition and open the flow a little more. That way you don't cut too deeply and you have matched flow which will work better for you.
PostPosted: Sat Jul 21, 2007 9:59 am
its easiest to scribe the line when you gasket match and port match, but thats just my opinion.
Deming, NM
PostPosted: Mon Aug 20, 2007 1:30 pm
Use blue Layout dye. Brush on, it only takes a little bit to dry. then scribe your line.. Dyechem? or something is a name brand. You can get some at your FLAPS.
PostPosted: Mon Aug 20, 2007 7:34 pm
what? FLAPS? what are you talking about? :oops:
Deming, NM
PostPosted: Mon Aug 20, 2007 8:50 pm
I believe it's your Friendly Local Auto Parts Store, but I could be wrong...
PostPosted: Tue Aug 21, 2007 12:57 pm
oh ok i thought it might be something like that, but when i first read it i thought he meant something else...lol
Deming, NM
