It is currently Mon Jun 08, 2026 2:07 pm
PostPosted: Sun Aug 12, 2007 4:05 pm
i just put a weber on my good running engine. i thought the carb was messed up so i put a weber on. now when you stab the gas pedal the engine shuts off almost. if u rev the engine slowly its fine. it seems to have its power but u just cant stand on the gas pedal
PostPosted: Sun Aug 12, 2007 6:30 pm
sounds like acclerator pump, but its a new carb, are you runnin to lean?
1979 4x4 LUV, rebuilt 1.8 and 27" bald tires
PostPosted: Mon Aug 13, 2007 9:31 am
i messed with timeing and it fixed it
PostPosted: Mon Aug 13, 2007 2:03 pm
Are you still running the EGR valve?
I put my Weber on my 4X4, and if the EGR is hooked up, when I rev up the EGR opens and it runs rough. If I unplug the EGR and rev it up it does fine.
I want to run my EGR. Any Ideas anyone?
PostPosted: Sat Aug 18, 2007 7:53 am
Your EGR problem is not a new one, Ford in the 70s had the same problem and we would get inline vac. resricters or a vac. delay valve and install in the vac. hose,this would cure the quick opening of the EGR valve and is still emissions legal.
PostPosted: Sat Aug 18, 2007 10:09 am
Cool. Thanks, TJ. I will see about a restrictor.
Users browsing this forum: Bing [Bot] and 22 guests
