It is currently Mon Feb 02, 2026 2:49 pm
 Post subject: shortest water pump
PostPosted: Wed Aug 08, 2007 2:01 pm
I'm looking for the shortest waterpump. Does anyone know which year and vechicle has the shortest setup for a S/b 350.
Thanks,
Craig R.
PostPosted: Wed Aug 08, 2007 2:46 pm
The short waterpumps were from corvettes, but you can just go on summit and get a short high-flow water pump and that will be the best setup.
-A
PostPosted: Wed Aug 08, 2007 3:25 pm
weinand makes small pumps available in summit, so does csi. it just depends how how much cooling you need as to what you order a9 if its a street truck or race truck)
79 luv drag truck
2 skidoos
2 quads
badass duramax diesel
PostPosted: Wed Aug 08, 2007 4:20 pm
A short Chevy water pump is just that, short. There is no difference in sizes of a short pump, they are all the same size but you can get different flow rates from different manufactures and different material like aluminium or cast. You can also get a reverse rotation as well for certain pulley set ups.
 Post subject: water pump
PostPosted: Thu Aug 09, 2007 5:52 am
I know they only offer the short and long. Does anyone know which vechiles have the short setup is it only vetts? or are others included?
PostPosted: Thu Aug 09, 2007 8:58 am
I believe it's any 55 to 68 model sbc factory equipped, and certain models after that.
PostPosted: Thu Aug 09, 2007 9:45 am
Thanks alot I'll check it out.
Craig
PostPosted: Sat Aug 11, 2007 11:49 pm
my '72 c/10 had a short pump on it.
front tires are overrated.
Users browsing this forum: Bing [Bot] and 17 guests
