It is currently Mon May 11, 2026 9:07 pm
 Post subject: head gasket, maybe?
PostPosted: Wed Jun 20, 2007 2:43 pm
I had a leak in one of my coolant hoses and I know it got pretty hot on the guage, fixed that but now it still takes water, I cant find anywhere that it leaks. Not to mention it KINDA runs different, just a little bit rough and i have to fill the radiator alot. Anyway, i stopped driving it and was wondering what you guys thought, can you tell if its the ehad gasket without tearing into it?
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Wed Jun 20, 2007 3:45 pm
compression check
And you might just pull the plugs if the cylinder is getting too much water the plug will be fouled if it is still firing it will look like it it WAY lean on the bad cylinder.
PostPosted: Wed Jun 20, 2007 7:25 pm
does your oil dip stick look like a milkshake? This might sound dumb but are your also adding 50% antifreeze to your h2o. antifreeze also raises your boiling point.
PostPosted: Wed Jun 20, 2007 11:39 pm
yea my Luv is doing the exacted same thing but it past smog with flying colors and its not smoking I have to add water and it runs Rough
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Thu Jun 21, 2007 2:45 pm
my oil is clean, well at least from water but last night i looked at it while running when i first started it up. there is a hairline crack on the exhaust manifold with water coming out of it. So i think ima go pull the head off now and see what i see :evil:
PostPosted: Fri Jun 22, 2007 6:43 pm
head gasket was good, well no breaks anyway. i talked to a guy and work and told me to look at each spark plug and the shitiest looking one there should be a crack in the head. does this sound right?
PostPosted: Fri Jun 22, 2007 6:53 pm
He could be. The g180 head is not the best and cracks often. You may have to get it pressure tested to find the problem.
Users browsing this forum: No registered users and 87 guests
