It is currently Sat Jun 27, 2026 4:24 pm
 Post subject: truck dies out
PostPosted: Tue Jun 05, 2007 8:39 pm
hello. i need advice, i have a chevy luv 4wd with 60218 orig. miles, i just had the alternator and the regulator (original) replaced. i have a brand new battery all done today.
it has a new air filter, all hoses are new, it dies out on me if i take my foot off the gas, could it be fuel filter? :?:
Happiness is stroking the lizard
(what?! i have a five foot iguana;
what were you thinking ;) )
OUCH!
got luv bumps?
PostPosted: Tue Jun 05, 2007 10:08 pm
Its possible.
Are the rpm's low, just before it dies? May need to adjust the idle stop screw.
PostPosted: Tue Jun 05, 2007 10:13 pm
Check that the idel/ fuel cut off solenoid has power when the key is on. If it doesn't, you can run a jumper from the fuse block over to it.
