It is currently Sat Jun 27, 2026 12:54 pm
PostPosted: Sun Jun 03, 2007 12:11 pm
Where can I find a pair of rear brake drums for 78 LUV?
78' LUV Mikado, Old
PostPosted: Sun Jun 03, 2007 6:01 pm
http://www.partsamerica.com/ProductList ... chfor=Drum
PostPosted: Mon Jun 04, 2007 9:26 am
thanks
I saw these and almost ordered them online. But Autozone had them aswell, but not on there website. I had to use the part number from Kragen, just had to take the two letters off of the front of the part #. The Bendix for only $33 instead of $55. Saved about $100 by going to autozone rather than Kragen.
Changed the rear drums, rotors shoes and pads, leaking wheel cylinder.
What else should be replaced while Im in this area?
78' LUV Mikado, Old
PostPosted: Mon Jun 04, 2007 5:51 pm
Check all rubber hoses going to each wheel for leaks or cracks, replace if needed. Other than that you should be fine.
