It is currently Sat Jun 27, 2026 5:40 am
PostPosted: Wed May 30, 2007 10:02 pm
Australian LUV Guru
Im unsure where my brake bias valve is.
Image Image Is it built into the master cylinder?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed May 30, 2007 10:48 pm
I wouldn't think so. Follow your brake lines down. There should be a junction block. That should be it. I think mine has Nibco cast on it, but don't quote me on it.
PostPosted: Wed May 30, 2007 11:19 pm
Australian LUV Guru
Single line travels to rear then splits at diff, single line for front travels to firewall then splits (see pic) two lines travel to brake calipers. No bias valves any where. Image :?
PostPosted: Wed May 30, 2007 11:50 pm
If you have a single line to a splitter from each reservoir then I'm at a loss.
PostPosted: Thu May 31, 2007 6:25 pm
sorry dont mean to hijack the post, but you have a CLEAN truck, or so it looks that way in the pics! anyway can you put a valve in the rear brake line to shut it off when needed to do burnouts? it would be a cheap line lock!
(PLATINUM STREET RODS)
Deming, NM
PostPosted: Thu May 31, 2007 9:02 pm
Australian LUV Guru
I dont recomend a valve in the brake line, will you remember to turn it on again after a burnout? Invest in a electronic solenoid line locker, wire to one of those big red switches that light up when switched on.
PostPosted: Thu May 31, 2007 9:03 pm
Australian LUV Guru
I still hav'nt found my brake bias valve :?
PostPosted: Fri Jun 01, 2007 12:12 am
I'm betting you don't have one. Probably Australian model differences, like RH drive, diesel available in 1980 4x4, etc.
Just curious--where does it get the vacuum for your brake booster? A belt driven vacuum pump, or electric one? Diesels engines develope no vacuum normaly. Looks like a very clean, well cared for truck.
PostPosted: Fri Jun 01, 2007 1:10 am
Australian LUV Guru
Theres a vaccum pump on the back of the alternater.
PostPosted: Fri Jun 01, 2007 1:27 am
I think it would be safe to say your truck doesn't have a external bias valve for the brakes,it's built into the master cylinder.You notice that your reservoirs are different sizes for front and rear. (usually front brakes have bigger)
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Fri Jun 01, 2007 3:09 am
Australian LUV Guru
Im going to agree with you Mad Dog, i tore down a spare to see what was going on inside. Inside i found two plungers separated in the middle with a spring, looks as tho when you brake, the first plunger moves then when spring is compressed second plunger moves. Applies more fluid to the front than the rear.
Users browsing this forum: Bing [Bot] and 54 guests
