It is currently Sat Jun 27, 2026 4:09 am
 Post subject: custom intake trouble
PostPosted: Mon May 28, 2007 4:00 pm
i bought one of those Spectre cone filters to put on my truck, and its too big to fit under the hood just clamped to the top of the carb. I went back to Autozone and got a 90 degree elbow. it fits under the hood now, but the carb and the tube are two different sizes, the carb is bigger, and it wont let the tube clamp down tight. any suggestions how to fix this? :oops:
(PLATINUM STREET RODS)
Deming, NM
PostPosted: Mon May 28, 2007 6:51 pm
jet one like this ... fits right on
PostPosted: Tue May 29, 2007 9:54 pm
fixed my intake... just ground a little material off the clamp, so the two sizes would fit, on another note, what makes that noise? whenever you take off it sounds like a jet engine or something. What makes that noise?
Deming, NM
PostPosted: Tue May 29, 2007 10:01 pm
sucking more air
PostPosted: Tue May 29, 2007 10:09 pm
well, if its sucking more air, should i run the carb a little richer? please tell me which screw to turn :oops: , i dont wanna screw up the settings on the hitachi. probably never get it right again, lol
Deming, NM
PostPosted: Tue May 29, 2007 10:21 pm
sorry no help there... never messed with one, try the manuel, or some one might chime in... i never adjusted mine gust left it the same, dont know if it was good or bad but changed to weber about 3 months later
PostPosted: Tue May 29, 2007 10:44 pm
hmm... ill probably leave it alone for now, its my daily driver so i dont wanna mess things up. Do the cone filters really give you more horsepower like the ricers say?
Deming, NM
PostPosted: Wed May 30, 2007 2:16 am
PITA Old Fart
Uh...no.
But like everthing else they put on their cars, it looks real nice. :lol:
PostPosted: Wed May 30, 2007 5:28 am
on the bong
tumwatertaz wrote:
Uh...no.
uh huh... but only if u have a cold air intake, or relocate airfilter to a place that will push air into it. Not allot of hp just 2 or 3 extra, but every little helps. and there pretty, K&N's also give u a few extra horses.
Proof it adds hp instead of pipe to filter to more pipe to intake, its filter pipe intake. of corse it adds hp
PostPosted: Wed May 30, 2007 9:45 am
Just for your info there are no screws that you can turn to richen the fuel it is done by changing the main jet. Don't worry about it as you did not chang things enough to make that bid a difference as you are still getting hot air in your motor anyway.As for the sound it was always there just covered up and muffled by the stock air filter housing. They were designed that way.
PostPosted: Thu May 31, 2007 6:21 pm
cool, thanks for clarifying tj. oh one more quick question, which vacuum lines can i take off and plug? i know to leave the tube to the dizzy, but since i took off the smog pump, and threw it as hard as i could, then found it and pissed on it :lol: , what tubes can i plug? :cry: my poor engine looks like a premature baby or something with all those tubes and stuff stuck on it! :cry:
Deming, NM
Users browsing this forum: Bing [Bot] and 15 guests
