It is currently Mon Jun 29, 2026 11:00 am
 Post subject: Home Made Headers
PostPosted: Fri May 11, 2007 9:23 pm
Anyone out there build their own set of headers?
I built a set of equal lengths for my 'yota and am debating on whether I want to build another set for the LUV. They're a pain in the rear but saved me a bunch of money! I just ordered up a bunch of U-bends and straight pieces from summit and went to work on them. This time I'm going to have a mandrel bender so they won't have as many welds on them. Anybody have any pics of LT headers stuffed in a LUV to give me some ideas?
PostPosted: Fri May 11, 2007 10:03 pm
There's a few pics of mine scattered in the link, a couple more maybe in the sig. thread. Don't know if it will help ya, but it's all I got. Mine have the first 3 tubes inside the frame, the rear tubes are outside the rail, and the collectors are slip on. A local shop built mine. They look like a pain, but I can get a socket and ratchet on each plug, about a ten minute plug change unless whatever engine i'm running needs to have the plugs indexed. With the set back you are going with, I'd imagine you will have to have 2 rear tubes outside the frame, at least on the drivers side. Hope this helps.
http://forums.luvtruck.com/viewtopic.php?t=11796
PostPosted: Sat May 12, 2007 12:17 pm
I had change a couple of the tubes on mine because I run angle plug heads and it was a VERY tedious deal. I cant imagine building a whole set.
PostPosted: Sat May 12, 2007 4:10 pm
Nothin real hard about it, it's just time consuming. But when you have too much time and too little money it's the way to go :smt023
PostPosted: Sat May 12, 2007 4:12 pm
I'm going to see if I have room to run them all outside of the frame like I did on the 'yota. We'll see though
PostPosted: Sun May 13, 2007 7:09 am
Here are some pic's of mine and they are outside the frame.
PostPosted: Sun May 13, 2007 10:37 am
You have any problems with the tires rubbing on them? I was looking at mine yesterday and it looks like it's gonna be pretty tight trying to squeeze all the tubes outside the 'rails
PostPosted: Sun May 13, 2007 10:48 am
I have a set of old v-8 landcruiser conversion headers on mine,they work like a fenderwell header over the frame,and if you have the motor set back the tires miss them.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Mon May 14, 2007 5:12 am
When i make a full lock to lock turn my tires will just rub them.These are 2" tubes and i have a Pinto rack-pinion steering and i have pizza cutter tires and wheels on it. But i think that if you hold the tubes against the frame you will have little problems if any.
 Post subject: look great
PostPosted: Thu May 31, 2007 7:34 pm
they do look very good
Users browsing this forum: Baidu [Spider] and 36 guests
