It is currently Mon Jun 29, 2026 4:49 am
PostPosted: Tue May 08, 2007 11:26 am
so im getting a turbocharger, and im gonna have to build the rest of the parts for this but i need to know.. with a stock engine running 5psi of boost what kinda of carb would be enough to supply the G180-(T) on a blow through system?
PostPosted: Tue May 08, 2007 11:52 am
You may want to contact Gemracing. He makes manifolds for this & has alot of experience turboing Isuzu G motors (running sub 10 1/4's). He's in Australia but you can ask his recommendations & advice. Keep us updated on the build!
_________________________
83 Isuzu I-Mark 1.8
01 Saturn L300 V6
PostPosted: Tue May 08, 2007 12:39 pm
PITA Old Fart
Since you are running a stock G180, use the weber 32/36.
PostPosted: Sun May 27, 2007 4:35 pm
i found a blow through turbo kit but ide prefer a system where the air fuel get mixed before it gets compressed not durring the process, dose anyone know of anything like that?
Thanks,
-Dustinicus
 Post subject: Turbo
PostPosted: Thu May 31, 2007 12:13 am
It's going to get pressurized any way you do it. What would the difference be? You are going to have to back in a rejet anyway to get the best tune.
PostPosted: Mon Jun 04, 2007 9:16 pm
yeah i dont wanna use the blow through system cause i hear that the compressed air going through the carb can blow the parts in it out and make it so it wont work right, and i dont wanna have top replace the carb if i dont have to every time i decide to step on the gas a bit
PostPosted: Tue Jun 05, 2007 4:59 am
Yes it can be easier to do a draw through system BUT if you ever get a leak between the turbo and the intake it will be pressurized air fuel combination (can you say BOOM or FIRE)a blow through setup is allot better and if you get a carb that is set up for it there will be know problems. Most of the turbo/carb setups are blow through so they do work as well as they are allot easier to setup and fab.
PostPosted: Tue Jun 05, 2007 11:31 am
http://www.studebakerclubs.com/21stCenturyTurbo/Page5_21stCenturyTurbo.htm
Some good links at the bottom of this page. Dick has turbo'd and supercharged lots and lots of stuff...
Have fun :)
