It is currently Tue May 26, 2026 1:02 am
PostPosted: Fri May 04, 2007 10:21 am
I asked a mini-truckin friend of mine about doing an aux. compressed air setup. Was going to get a Harbor Frieght pump and plumb it into a tank. He suggested finding a used York a/c pump. Then plumb that into a tank.
My question is, has anyone done this setup on the Luv? My concern was proper revolations. He said any belt would be fine and not to worry about speed.
2003.5 Mazdaspeed Protege
1987 Mazda RX-7 Turbo II
1980 Chevy Luv 4WD
2005 Honda CRF230
PostPosted: Sat May 05, 2007 1:01 am
Swap Specialist Mod
this si what im going to do when i bag my pup. i already have a york 210 compressor setup for air sitting in the dining room.
im still trying to figure out a mount for the compressor to the engine.
PostPosted: Sat May 05, 2007 9:54 am
I think the forum is fullsizechevy.com There's a huuuge sticky thread on doing this.
1980 Chevy Luv 4WD
2005 Honda CRF230
PostPosted: Sat May 05, 2007 10:35 am
I had one on mine back in the early 90's,just fab up a mount and a switch and you are good to go.I will warn you i had one that the clutch locked up on and had to stuff a rag in the inlet so it didn't blow my tank up!
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
Users browsing this forum: Google [Bot] and 22 guests
