It is currently Mon Apr 06, 2026 2:53 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Feb 14, 2007 7:53 pm
O.k. got the call today . He had a big money job come in and had to stop work on my project after he finished the first set . So i'll be picking up my set friday evening . I am racing saturday so conversion will be after that .
PostPosted: Wed Feb 14, 2007 8:17 pm
Keep us posted.
PostPosted: Fri Feb 16, 2007 5:24 pm
I got one set of spacer in my hands . They are made of 4140 . It will be next tuesday before I get a day off to attempt the conversion .
PostPosted: Sat Feb 17, 2007 9:43 am
I LUV it when somebody follows through on there plans i hope to see you up and stoping soon :lol:
PostPosted: Tue Feb 20, 2007 5:17 pm
t.j. Sent you a pm about this conversion .
PostPosted: Wed Feb 21, 2007 10:15 pm
Well , Im almost finished with this conversion and I must say it has been a chore . The interferience fit inner or big bearing coller i had made were a little on the big side , so I had to polish about .002 off of it to get it to fit correctly , sanding cloth :roll: . The caliper mount had to be ground on the inside faces to make it wide enough to fit the new wider rotor , mine ended up about .025 clearence between the rotor face and caliper mount bracket . The clearence had to be "shimed"withdifferent thickness washers to center it on the rotor and allow clearence front and back . The new rotors and new brake pads are thicker than the factory Luv caliper will open , so I had the pads surfaced to allow them to fit . I used the toyota inner and outer bearing with the Luv spindle washer , nut , and retainer and a new cotter pin . The dust sheild and spindle mounted caliper bracket had to be opened up to allow the rotor to set all the way in . I used a National seal #471868 this seal fit , but is a double lip seal and the factory was a single lip in the center . I also replaced the toyota metric studs with 1/2 " ford studs They are .560 Knurle . The Rotor swap looks factory and now I have the same bolt pattern front and rear . I have not driven it as I don't have my new rims yet . I will post a drive report soon . I believe that this is a good swap for a mechanically inclined person who has a garage and does not drive there truck as a daily driver . I planned for this swap for about 2 months and there were alot of challenges that popped up . Sorry for such a long post . If you have any specific questions T.J or myself can probably answer them .
PostPosted: Tue May 01, 2007 11:31 am
getting started on mine today. dropped the spindles and hubs off at machine shop.
thanks for the seal # hotrod!!! :wink:
AINT RIGHT MOTORSPORTS
PostPosted: Tue May 01, 2007 12:05 pm
PostPosted: Sun May 13, 2007 11:41 am
finished my toyota hub swap friday and everything went smooth. i am so glad to get the draglites back up front!!!!
PostPosted: Sun May 13, 2007 4:30 pm
Sweet , Toyota rotor conversion #3 in the books . Glad to see you got it figured out . Did you have any problems ? Any thing you did different from mine ?
PostPosted: Sun May 13, 2007 11:09 pm
no probs. i did machine the rotors all the way down to spec. did some grinding on the caliper mount to clear the rotor. and spaced the caliper mount out with three 7/16 washers on each bolt. the machine work cost me $55 dollars and 2 seals. the rest was labor. cheapest thing i have done to my truck yet and it made a world of difference in appearance!!!!
and it stops straight to! :wink:
PostPosted: Mon May 14, 2007 5:29 am
:smt023
