It is currently Wed Jun 10, 2026 3:09 am
 Post subject: Front Main Seal
PostPosted: Fri Mar 23, 2007 3:55 pm
How difficult is it to replace the front main seal? Do I have to pull the valve cover and drop the pan? My Haynes manual is useless as always.
 Post subject: Re: Front Main Seal
PostPosted: Fri Mar 23, 2007 4:01 pm
I concur.
FIAA: Color Guard
PostPosted: Fri Mar 23, 2007 10:08 pm
The front main seal is a round lip type pressed in seal. there is no reason to pull pan. I changed one in the truck a long time ago. It was not he easiest thing to do, but possible. Remove fan and front crank pulley and pry out old seal without damaging front cover. I can't remember but I might have pulled radiator and grille to get access to drive new seal in. I then used a large hollow driver that fit over snout of crank to drive new seal in sqaure, but if your good with a hammer and punch you may not need a driver. Air conditioning will complicate this if your truck has it. :roll:
PostPosted: Sat Mar 24, 2007 5:59 am
Thanks for the info!
 Post subject: Front main seal
PostPosted: Sat Mar 24, 2007 8:38 am
I posted a video of myself removing a front main oil seal...
Check it out down about 3/4 of the way on this page,
http://forums.luvtruck.com/viewtopic.ph ... &start=420
'78 1.8L 4-speed Fleetside
Image Image
