It is currently Tue May 19, 2026 7:23 pm
 Post subject: cheap tricks
PostPosted: Mon Apr 21, 2003 5:41 pm
any cheap tricks for more power?
PostPosted: Mon Apr 21, 2003 6:54 pm
No.
PostPosted: Mon Apr 21, 2003 6:59 pm
But seriously, are you talking about a stock motor? What do you mean by cheap?
PostPosted: Mon Apr 21, 2003 7:00 pm
higher octane gas, better oil, run your timing about 3* past stock. Thats about all i can think of
PostPosted: Mon Apr 21, 2003 7:07 pm
if possible remove the cat converter...k&n air filter...flip your cover on the air cleaner upside down < OLD trick.. :lol: ).....and what mepr said.
PostPosted: Tue Apr 22, 2003 4:51 am
find a cheap used nitrous kit :twisted: .probably more than your wanting spend though
PostPosted: Tue Apr 22, 2003 7:22 am
Quote:
flip your cover on the air cleaner upside down < OLD trick.. ).....
:? :? i have never heard that. does it really work :?
PostPosted: Tue Apr 22, 2003 8:16 pm
well in theory it does.....allows more air flow into carb therfore a little more power.
i dont think there has ever been any dyno proven results on it tho :wink:
PostPosted: Tue Apr 22, 2003 8:36 pm
Pacesetter has a header that might help you squeeze a few more horses
There is also a few dual port intakes on e-bay you might want to check out
Try platinum spark plugs and high quality wires
K&N airfilters are always a good way to go too
PostPosted: Thu Apr 24, 2003 8:26 pm
im running the pace setter header and well it works vary well and gave me vary noticable power but it is expensive ($175 after frieght i think).
On the cover flipping, i have a buddy who does that whith his 87 GMC whith a 350 and while it dosnt give you noticable power it dows make the motor run smoother.
PostPosted: Thu Apr 24, 2003 9:49 pm
umm cheap trick??? ummm ohh how about a Type R sticker like the honda ricers do? they think by putting a Type R sticker makes the car twice as fast!!
PostPosted: Thu Apr 24, 2003 11:25 pm
NOS stickers and Folger's can exhaust parts seems to help all the ricers around here.
PostPosted: Thu Apr 24, 2003 11:30 pm
You might concider cleaning out everything in your truck that isn't needed. You could be hauling around alot of extra weight that you dont want. Every little bit helps.
PostPosted: Fri Apr 25, 2003 12:35 am
Seriously though, it depends on the definition of cheap. A good tune-up will help a lot, cap, rotor, points, condensor, plugs, and wires. It costs a lot less than things like a header or a weber carb, but if you're running old parts it can make a world of difference. A new air and fuel filter also help. (Anyone have a part number for a K&N replacement for the stock air filter? I keep meaning to measure and find out myself, but keep forgetting.)
Before you go buy a bunch of parts expecting it to be simple, keep in mind that the points need to be gapped correctly or the truck will run badly if at all. A copy of the Haynes LUV shop manual will help a lot for this kind of info if you don't have something already.
Once you have the whole thing back together and running, this is a good time to adjust the timing. Like MEPR said, running a little bit more advance on the timing seems to help. On my 4x4, at least 15 degrees is a must or it rattles and pings like maracas. It runs fine like that, so I never took the time to find out why, but my 2WD runs great dead on 12 or even lower. Experiment with it, and see what works for you.
PostPosted: Fri Apr 25, 2003 7:36 am
1980 CHEVROLET LUV TRUCK 1.8L L4 2 BBL. E-2760 Air Filter
your going to have to order it. i just went to a parts store and sized mine up with the ones in the store and found one a half of inch deeper and it fits fine :D
PostPosted: Fri Apr 25, 2003 5:52 pm
pull the head mill it enough to clean it up do a mild port and polish job install header and better intake and carb. thats about all you can do thats farily cheap. i guess it all depends on what you call cheap too. see if someone can grind you a cam. i have heard of companies that can regrind your original to give you a bit more lift and duration. i don`t have any info on them though or the quality of it.
PostPosted: Sat Apr 26, 2003 6:35 am
If you want to do it cheep, then just remove all the garbage they put on the stock engine.I just rebuilt my 80 stock engine and only kept what the engine needed to run. It seems to have almost twice the power as my street legal 79 stock engine with all the crap on it!! The only thing is ...you cant pass the emissions test if you remove all that. By the way i removed 112lbs.
