 Post subject: Tilted's Rims
PostPosted: Tue Feb 11, 2003 8:24 pm
Hey tilted?What size rims do you have. :D
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Feb 11, 2003 10:12 pm
They are 15x7's centerline HT's. I like them but they stick out far enough front and back that I cant go any lower as they will hit the fenders. I seen your post aout 17's fitting, it all depends on what width of rim and tire size you run. If you go any wider than 6 inch wide rims they will stick out. I want to go with 17's next time around but either I will have to do some major suspension modifications or have special 17x6 rims made by a billet company. I don't even know if there are tires that would fit a rim that size.
