It is currently Tue May 26, 2026 1:37 am
PostPosted: Sat Jan 28, 2006 9:51 pm
Hey guys how do most of you reattach your beds when you cut your rame rails and move them in.
PostPosted: Sun Jan 29, 2006 10:27 am
I set my bed on and "squared" it up. I then used 2X3 .120 wall metal and cut a 45 degree angle at the end where it bolts to the bed. I drilled a hole that would use the stock size bolt for the bed. I then welded the square end to the frame and added gussets. Do that 6 times and your done.
PostPosted: Sun Jan 29, 2006 10:54 pm
thanks man, that helps me out a lot.
PostPosted: Sun Jan 29, 2006 11:14 pm
I will try to get pix tomarrow for you.
