It is currently Mon May 25, 2026 2:30 pm
 Post subject: Power door locks
PostPosted: Sun Jan 22, 2006 8:02 pm
Has anyone tried adding this feature to their luv?
PostPosted: Sun Jan 22, 2006 9:21 pm
it's easy! you get the acuator and bracket then you mount the acuator in the top hole in the door by the latch and point the acuator down at bottom of the door. next run the rod down to the lock rod install the clamp and run power to the relay\keyless entry.
PostPosted: Sun Jan 22, 2006 10:53 pm
Yep, pretty simple. have it in my truck.
Resident lurker
PostPosted: Mon Jan 23, 2006 12:31 am
hey guys how much were the whole lock setup and where do you get them?
