It is currently Tue May 26, 2026 1:38 am
PostPosted: Tue Nov 08, 2005 10:13 pm
I am done with the frame welding,painting and anything to do with the frame. I hope to get my trans back tomorrow, if so I will be installing that and the cab tomorrow afternoon. I decided to run the stock LUV alt as it works and it is a direct plug in.
PostPosted: Wed Nov 09, 2005 12:48 pm
dude that rear is really.....really....really....narrow!
Lookin good man.
8)
03Cobra
PostPosted: Thu Nov 17, 2005 5:14 pm
LUVTruck.com's Cornholio
Now those are some meaty meats!!!! I wish I could afford a setup like that on my rig!
PostPosted: Thu Nov 17, 2005 6:08 pm
that's looking sweet... when will you have the bed tubbed out like we talked about ?? seems like you are making great progress on this little truck
PostPosted: Thu Nov 17, 2005 8:24 pm
I am finished with the cab and engine area. I also have the brakes in working order. The bed I will start on this weekend. I hope to be driving it this time next week. Like I said, this turned out to be a bigger project then I started to do. I have decided on a color. Chrome yellow with SS stripes. The stripes will be 04 Harley white with the purple pearl. I would like to drive it a month or so before it goes to paint. When done I am thinking of doing the same to a Vega for my wife.
PostPosted: Sat Nov 19, 2005 2:01 am
Looks like things are coming together really nice!!!!! Keep it up, and don't forget the pics :wink:
PostPosted: Sun Nov 27, 2005 9:20 pm
Well I finally got the bed on today. It is just sitting there and I hope that tomorrow I can weld the brackets to bolt it down. If I can there is no reason I can't get it to the muffler shop Wednesday and be on the street then. It's getting close. It will kinda suck when it goes into the paint shop. I have alot of time in it and want to enjoy it.
The bed is alittle twisted, but I will take care of that when I fab up the mounts.
PostPosted: Sun Nov 27, 2005 10:27 pm
Swap Specialist Mod
man that thing looks just like peeroys truck 'cept for the bigass tires :D
8O
PostPosted: Mon Nov 28, 2005 6:16 pm
Lookin good man! Now ya need a bigger motor to turn all that rubber! I like!
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Mon Nov 28, 2005 6:26 pm
Small problem. I took it out on it's maiden run today, and well the rear is alittle light. At first I thought my trans was slipping, but a check in the rear mirror proved different. That's OK, I will just stock up on tires.
PostPosted: Mon Nov 28, 2005 6:28 pm
lmao - so much for traction huh
63 Nova
74 Camaro
PostPosted: Mon Nov 28, 2005 6:29 pm
Maybee they need to be hotter?
PostPosted: Mon Nov 28, 2005 7:02 pm
If those are sportsmans you may never get em to hook, those things are hard as a normal street tire, but try a big smokey burnout to be sure lol
63 Nova
74 Camaro
PostPosted: Mon Nov 28, 2005 10:09 pm
LOL! I wish I could see the heating process. :)
BTW, you might also want to mess with the air pressure.
PostPosted: Wed Nov 30, 2005 1:36 pm
Japanese Redneck
sportsmans and sportsman pros dont hook and doing a burnout makes them worse. best treaded tire in that size is the MT ET streets..... or just cut a couple grooves in a ET Drag and buzz the "not for highway use" off with a whizzer wheel.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Nov 30, 2005 3:00 pm
Being a sprint car racer, I perfer to stay with Hoosier's. Hell, for that matter I have a shit load of rc-1's. I know they will hook.
PostPosted: Tue Dec 13, 2005 10:18 pm
are you planning on running your psi down when you go to the track? might help you connect a little better
