It is currently Mon May 25, 2026 3:16 pm
 Post subject: 4 link adjustment
PostPosted: Wed Jan 22, 2003 10:27 am
I have been looking and I found a good article in Febuary 2003 volume 4 number 2 of SUPER ROD. I just happened to see it at the local books a million and have never even heard of the magazine before. Until this I really haven't been able to find much info for the street I keep getting dirt track setup. Maybe others running a 4 link could list there setup positions.
stripped and just a memory!
PostPosted: Wed Jan 22, 2003 9:33 pm
hey rat i saw another safety you might have to lok into i forgott your running a 4 link. you have to have flat washers on both sides of your rod ends to prevent bearing pull out.if you haven`t allready done that. later terry :twisted:
PostPosted: Thu Jan 23, 2003 8:30 pm
I bought Morrison poly bushed street ends. No bearings
PostPosted: Sat Jan 25, 2003 12:50 am
i also run the poly bushings ,and i love them .i run my 4-link bars -the lower about level with the ground and the top bar, the front[frame side] about an inch lower than the back of the bar [the dif side].but that is only half of the set up the shocks play a huge part in the set up i run the 90/10
in ft and the 50/50 in the back.the air pressure also is a big part ,i run the m.t.street slick and found that 13psi works best i hope all this helps
